0 Members and 311 Guests are viewing this topic.
verpies
Quote from: Zeitmaschine on December 01, 2012, 06:54:27 PM
The graph is borrowed from Wikipedia so I think it denotes the wavelength.
Ah, so the black vertical lines are not a part of the waveform at all.  They do not denote voltage spikes.
Whatever goes off when the wire of a coil is disconnected from something like a battery etc. by means of a mechanical switch.
That would be the current flowing through the coil's winding.
The coil will rebel to such an interruption attempt and will generate high voltage of such polarity and magnitude, that the current through the coil will keep flowing unchanged in the same direction.
But to have something to think about: What strange effects could happen (in a coil) if a sine wave goes off right at its peak, so each sine half wave would be cut into a quarter wave. The left side is still there, the right side is missing. Hmmm ...
Exactly this situation is described in this post.
Note, that the lower blue trace (L2 current) represents 3/4 cycle of a sinewave, that is abruptly terminated at its peak.
Using this method, it is possible to generate a flyback pulse in the MegaWatt range, albeit only for several nanoseconds.
The interesting property of such short pulses happening at low repetition frequencies, is that they contain almost all the frequencies up to 1/t, according to Mr. Fourier.
Zeitmaschine
Quote from: verpies on December 01, 2012, 08:07:08 PM
A rebelling coil could  be a good thing. Better than a coil which sits there and does nothing. :D
But since the generated high voltage alternates at 50 Hz (I think it should be) then the positive high voltage peak will attract electrons from ground whereas the negative high voltage peak should return the electrons to the ground.
So isn't this in essence that what the TK device does? Namely make electrons oscillate in a ground connection?
Looks quite complicated. What would Tesla say to MOSFET, IGBT, GaAs BJT, DSR diodes etc. ?? ::)
Apropos: The page count is 60 and still no working Dally replica? How could this be?
Сергей В.
Zeitmaschine our planet several billion years flying through Universe and we still don't know why and how ?? Don't mention other Stellar objects!
Let's don't asking more questions but trying to answer on some of them OK ??  :D
On this Tiger2007 video we can see on oscillograph pure  Over Unity. And we know how to make it. Problem is how to take power of contour without quenching generation. The principle is one on present level of our knowleadge. Excitation LF contour with sharp mono-polar or unidirectional DC pulses. We can see how amplitude of Sin wave rise from 200V to 400V when LC contour was excited with HF pulses on positive half-wave cycle. Questions about slope of the pulses, duration, duty cycle of HV DC Nano-Pulses, resonant frequency of LC contour (in my oppinion must be 50 or 60 Hz), grounding and best variant for taking off power are still open.
Tiger2007 video
http://www.youtube.com/watch?v=Um7J_5FwVq0
Everything must be experimentally verified as Tesla said otherwise all our theories are trash without practical use !!
wasabi
Quote from: yfree on September 21, 2012, 01:12:41 PM
I am wondering, why McFreey's analysis is rejected, without any rationale given, while the proven wrong approaches are perpetuated.
Perhaps because it is obvious, that the avalanche multiplication of relativistic electrons (or positrons) requires nuclear reactions in which one beta particle causes the release of at least two beta particles.
...and such multiplying beta nuclear reactions do not exist, do they ?
Without them, the number of released betas cannot grow in McFreey 's  scheme :(.
xenomorphlabs
Quote from: Сергей В. on December 02, 2012, 04:37:00 AM
On this Tiger2007 video we can see on oscillograph pure  Over Unity. And we know how to make it. Problem is how to take power of contour without quenching generation. ... grounding and best variant for taking off power are still open.
The problem is not new and solution approaches to that problem do exist (and that for more than 15 years). I have mentioned it about half a dozen times in this thread.
On that graph it is not possible to see overunity, because you could only see that if he would display voltage AND current together having the right phase difference.
