0 Members and 475 Guests are viewing this topic.
Hoppy
Quote from: Zeitmaschine on December 04, 2012, 10:15:18 AM
What findings do we have so far:
1) 12V input can generate up to 650V output simply by opening a switch which is connected to an iron core transformer.
2) A (DC) current can flow (to/from ground) without a closed circuit provided that the voltage (potential difference) is high enough.
3) The Kapanadze device can generate a high current to ground without a return path (no closed circuit).
Therefore what do we need?
The reading on the clamp meter was very likely misleading if the current was not sinusoidal at mains frequency, as has been pointed out and discussed earlier .
DC current cannot flow to/from ground without a return path, so therefore a high current cannot pass to ground without a return path.
More thinking is needed as to how TK provides a return path.
sparks
Quote from: Сергей В. on December 03, 2012, 03:30:59 AM
Gift from Inogda. He is our TPU guy !!
ANIMATED GIFS !! WATCH IN TOTAL COMMANDER PIC VIEWER !!
    I particularly like the inductance one.  If you place the flywheeled turbine with 2 elevated resevoirs and start with one full and the other empty you have yourself a resonant circuit.  Without the turbine if we have one resevoir filled and the other empty (capacitor charged state) a switch and a capillary section of pipe (resistor) this would result in a simple discharge of the cap.  Water would flow through the capillary section until the water in both elevated resevoirs were at equal heights.  Take the same sceanario and add the turbine  (with attached flywheel). Open valve.  At first very little water flows.  You could actually open and close the valve so fast no water flows.  The water flow is totally impeded.  Given time the water starts to flow and accelerate the flywheel.  The water level in the two tanks reaches zero differential.  Then the majic.  The water now gets pumped from the original high level resevoir  until the exact opposite conditions exist we started with.  The water is empty in the feed resevoir and full in the collector resevoir.  The flow now reverses and continues oscillating back and forth until the resistance of the pipe to the flow brings the system to rest with both resevoirs at the same level.  The advantage of this system is that we can easily add water to the tank that is near empty and take it out at the resevoir that is filling.  Could this be Tesla's tank in a lake energy sink scheme?  How empty does the resevoir have to be before water flows into it from the ambient?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Zeitmaschine
Quote from: Hoppy on December 04, 2012, 10:41:45 AM
5000W divided by 220V equals 22.73A, the reading shows 22.9A, so it seems to be the correct value.
It can. I have checked this out by means of a charged picture tube and my fingers a few times already. So I know fore sure.
Changing the polarity of the high voltage provides the return path. In other words, the electrons are vibrating at 50Hz to and from the ground connection.
I think if someone holds the TK device in his bare hands and then the ground connection fails while it is running, he would get surely a nasty electric shock.
Hoppy
Quote from: Zeitmaschine on December 04, 2012, 11:15:36 AM
This is interesting. Can you please draw out this concept showing the source of energy and switching arrangement?
idzaza
Quote from: captainkt on December 04, 2012, 09:18:39 AM
@idzaza, sounds as if you have been playing as I have. Very difficult to work out the output, fairly easy to work input with watt meter.Only going by brightness comparison for out . The most amazing thing I found was that when I unwind the pancake and form it around a 45mm tube the coil is only tiny just over 3 inches long using the 10 metres of litz wire and this will light a 3kw industrial fire and half a dozen 100w bulbs no problem. My hob is single from Maplins £35 new, once the internal fuse blows then only the coil and a few caps are salvageable . The wattage shown by hob is not accurate,they run at 950watts when showing 600 watts. Will keep in touch.
Keith
Ok, what you are saying is that I unwind the wire the one I used as a secondary right? then I wind it on the 45 mm tube and before that I need a primary wire like u say 3 inches long about 10 meter something thin wire, I can do that, but could you tell us if you had any extra net energy? it can happen that you get 3 4 kilowatts of power but still using 3 kilowatts of energy from mains.
Regards,
Zaza
