0 Members and 98 Guests are viewing this topic.
andrea76
Quote from: pix on February 14, 2011, 03:05:44 PM
@Ltbolo and all.
That is exactly what I do suspect.And refrigeration system example is a macro-world equivalent.
Please see William Barbat US Patent Application # 2007/0007844
http://www.rexresearch.com/barbat/barbat.htm
Pulsed coil radially expell what he states "inductive photons", what I do believe are electrons.That acceleration changes inertial mass of electron.Ballistic electron (not bound in metal lattice) changes: shape,mass and do exchange energy with the surrounding space- like refrigeration gas when changing its state from liquid to gas and back to liquid. A typical heat pump is OU device, the only difference is that we exactly know from where energy is taken- surrounding ambient air.
Anyway, I think there are a few ways to get OU:
1. Rotating magnetic field along conductor, like in typical 3 phase el. motor, the only difference is that B vector change is in the same direction as it moves. Pulsing 3 coils, overlapped, with 120 deg shifted signals circumferently along core made from another conductor.This is analogy to "squeezing electrons like water in the garden hose".
2. Feeding multiple harmonic frequencies to the piece of wire.Frequencies need to be choosen to create standing waves only.Standing waves "feeds themselves" and superposition of this setup gives travelling "kick" of large amplitude.Harness that "kick". Nice example was provided by Forest, see: http://www.youtube.com/watch?v=GMXlzCX5gio&feature=related
3.Utilizing phase change of electron ( Barbat way), when electron "jumps" from bound state in metal lattice to "free space"- something happens, they do exchange energy with enviroment ;-)
I have some more in my mind, but for now is enough.
Regards,
pix
very interesting note
forest
yes , interesting note ... we will find out that it's all about inertia and tapping gravity which is really the same source of energy as magnetic field.... sparks is also right about Tesla sink experiment related to RCL circuit
the final answer is reactive power, it is something which occur when inertial is changed ....
JJUK
Quote from: sparks on December 04, 2012, 11:05:31 AM
I particularly like the inductance one.  If you place the flywheeled turbine with 2 elevated resevoirs and start with one full and the other empty you have yourself a resonant circuit.  Without the turbine if we have one resevoir filled and the other empty (capacitor charged state) a switch and a capillary section of pipe (resistor) this would result in a simple discharge of the cap.  Water would flow through the capillary section until the water in both elevated resevoirs were at equal heights.  Take the same sceanario and add the turbine  (with attached flywheel). Open valve.  At first very little water flows.  You could actually open and close the valve so fast no water flows.  The water flow is totally impeded.  Given time the water starts to flow and accelerate the flywheel.  The water level in the two tanks reaches zero differential.  Then the majic.  The water now gets pumped from the original high level resevoir  until the exact opposite conditions exist we started with.  The water is empty in the feed resevoir and full in the collector resevoir.  The flow now reverses and continues oscillating back and forth until the resistance of the pipe to the flow brings the system to rest with both resevoirs at the same level.  The advantage of this system is that we can easily add water to the tank that is near empty and take it out at the resevoir that is filling.  Could this be Tesla's tank in a lake energy sink scheme?  How empty does the resevoir have to be before water flows into it from the ambient?
Hi sparks,
Are you able to see all the GIFS animated then? Like verpies, I am only able to see the switch analogy animated even with Windows Commander.
JJUK
captainkt
@idzaza, unwind pancake and wrap around tube feed from hob as primary then wind another 1 or 2 as secondarys again use wire from pancakes. The circuit tends to fire up straight away due to better impedance match. Can not say OU due to no way to measure output, but circuit is very lively and good for moral. Usually I end up overloading and blowing up hob then start over. I now know why it takes people years to get anywhere.
Keith
Zeitmaschine
Quote from: Hoppy on December 04, 2012, 12:23:49 PM
This is interesting. Can you please draw out this concept showing the source of energy and switching arrangement?
The source of energy and the switching arrangement? That's the One Million Dollar question! :P
TK says the energy comes from space surrounding us. Now that what surrounds us is the aether. So could it be that the aether acts like a high voltage capacitor which re-charges itself each time one tries to discharge it?
Therefore my next basic research #5: The polarity is reversed compared to #4, the switch has a capacitor in parallel and ground is connected via a glow lamp. As soon as the switch is opened  the coil generates a positive (high) voltage pulse. Since positive means there is a lack of electrons and since there are a lot of electrons in the ground a small current flows through the glow lamp and makes it flash.
So what could happen if the polarity of the voltage spike would not always be positive but reversed each time the switch is opened (say 100 times a second)? More current should flow through the glow lamp and the ground as a consequence. And isn't the generation (amplification) of current (not voltage) exactly that what the TK device does?
Have to think about this ...
