0 Members and 474 Guests are viewing this topic.
elementSix
That should be the focus, the wireless transmission of energy, by Tesla..  If your wanting to tap into the either, It would seem that wireless one wire power transmission would be part of the device.  Even in that TK video of the outdoor demo with all the 3-Phase Capacitors and the large coils, there is also a very large metal globe that is there.  Of course it might be for looks, but why go to all the trouble to set it up if he didn't need a large antenna.  It was talked about earlier on the blog about using a small HV Tesla coil with the toroid or globe on it.  Altered some way to gather either energy.  He is obviously using capacitors and their has to be some hidden in his box, Has anyone ever tried the 3-Phase Cap's with a ground wire on one of the poles?  Just throwin ideas around...
I have a really NUB question, I have a MOT and I hookup the single wire from it to a Bifilar pancake coil I made from speaker wire.  When it came out, the wire I hooked it up to had a lot less power in it and I could hardly feel the sting of the voltage, but the unused wire on the coil had a very good sting from the coil and it was not touching anything and wasn't hooked up at all to the MOT.  Could anyone tell me why that is??
verpies
Hoppy
The meter reading is the give away and the fact that a voltage was being read between the water pipe and wire indicates there must have been a return path to the water pipe from the device. The thick wire was IMO almost certainly a power carrying conductor, so the wire must have been at a different potential, probably above that of the pipe as indicated by the meter reading. This suggests that the pipe was not above ground potential (as I first thought) and that the source of power supply was connected at the device end and the ground was being used as the return. This explains why the ground around the pipe was so wet. The earth return from the radiator was probably too high resistance, even though it was buried deep and well watered. TK probably thought that having the earth wire at a good distance away from the device strengthened the illusion. A short and carefully concealed insulated wire from the lamp array down into the ground and connected to the power supply with the other side of the power supply connected to ground would have completed the circuit - simple!
Edit: I think a clue to how the 'live' feed is sourced can be seen in the 'Transparent Box' video. At 07:43 into the video the guy with the white shirt can be seen holding the lamp board whilst standing next to TK. Between and behind them the white iron balustrade can be seen with a heavy duty black insulated wire going over the top. it can only be seen for a split second before TK's body blocks the view. This wire looks the same type as the 'earth' wire used in the 'green box' video. The wire very likely drops to the ground and feeds power from the house to wherever it is needed in the garden for the demo's.
verpies
Quote from: Hoppy on December 08, 2012, 06:40:17 AM
A wire can easily be concealed from any camera operated by the inventor.
Hiding a return wire from the cameras operated by demobuyers and the demobuyer's eyes, would be much more difficult.
...albeit not impossible.
In this thread, we already discussed two viable methods of completing the circuit via a HV cable masquarading as a single wire :
1) A wire concealed inside the grounding braid.
2) Litz wire ( e.g.: Litz'ed braid )
A separate second wire, out in the open, is out of the question if demobuyers are roaming around while the whole device is lifted up.
Why don't we organize a fund-raiser and elect someone competent to send to Georgia to evaluate TK's demo in a scientific manner, once and for all  (e.g.: by calculating the energy density of his device as a Black Box)
It shouldn't be too difficult, with hundreds of people reading this thread...
Hoppy
Quote from: verpies on December 08, 2012, 03:55:35 PM
Agreed - difficult but not impossible.
However, a couple of questions that need to be answered: -
How many people in the video were the demobuyers and how many were part of the TK team?
If the meter reader was a demobuyer and the device genuine, why stop him from reading the voltage between the pipe and 'earth wire'?
At 11:15 into part 2 of the 'green box video', after the lamp array has been moved to a new position TK is seen to hand a loose wire (connected to the lamp array) to a guy who proceeds to strip it and connect it to the water pipe at 11:35. This seems to remedy the low light level problem, as the lamps now come on at full illumination. However, the heavy duty black 'earth wire' in TK's hands is still connected to a heavy duty white wire that drops to the ground and runs back towards the house. This wire can be seen at 12:32 on the ground below the battery on the table. The meter reader guy may not have noticed that the wire had been connected to the water pipe. This wire having been disconnected from the water pipe at the end of the video is seen to be quickly 'flicked' out of camera shot by a hand from two people!
As you suggest, we need to know the energy density of the black / green box because its quite possible that the device could have initially run for short periods of time from a set of batteries in the box and bolstered by an extrernal power supply when run-down.
