0 Members and 123 Guests are viewing this topic.
Hoppy
Quote from: verpies on December 09, 2012, 02:25:30 PM
So let's get suggestions from everyone here, about:
1) The parameters of the "Black Box", e.g.: max mass, max volume, time & power of continuous output, type of output. Load type.
2) What "externals" of the Black Box demo should be determined by the demobuyers.
3) When payment should be rendered, because TK will surely claim that he needs money apriori for parts to build the demo.
4) Who should collect the donations from the users of this forum.
5) Who should go to inspect it.
My suggestions for pt.1 is: 230 Volts of pure DC at 20 Amps for 12 hours with no external "input" from a max 40kg "Black Box" device so one man can lift it. Resistive load delivered by the demobuyer.
For Pt.2, I suggest: no external power input from a closed electric circuit, or from near field magnetic fields or from near/far RF EM fields.
For pt.4, I propose Stefan Hartmann as the fiduciary.
For pt.5, I suggest any user of this forum who has proven himself to be a practial Electronic Engineer and has a good handle on non-DC power measurement and wireless power transfer. I think we would need a good cameraman, too. Knowledge of Russian or Georgian language would be a plus.
Additional suggestion: -
Pt 6) Controlled environment - Area around DUT and full length of 'earth wire' to be kept clear once device is up and running. Any onlookers to be kept behind lines. Only investigating team and operator to be allowed within designated test area.
Jon_sparky
From the Thunderbolts team Electric Plasma Science is also beginning to see how electric currents can be generated from the universal source.
"As mentioned, a double layer is an electric charge separation region that forms in a plasma. It consists of two oppositely charged parallel layers, resulting in a voltage drop and electric field across the layer, which accelerates the plasma's electrons and positive ions in opposite directions. Since moving electric charges generate electricity, there is an electric current present. If there are sufficiently large potential drops and layer separation, electrons might accelerate to relativistic velocities, producing synchrotron radiation."
At times, a double layer might interrupt charge flow in the circuit, causing a catastrophic rise in voltage across it. The powerful energy release of the exploding double layer is sometimes observed in power transmission switchyards when a circuit breaker is opened incorrectly.
wow, isn´t That interesting ... and so simple ?
http://www.thunderbolts.info/wp/2012/12/06/double-layers-in-laboratory-and-cosmic-plasmas/
andrea76
Quote from: Jon_sparky on December 10, 2012, 06:35:51 AM
mmmm...like Perrigo and roy Mayers statement about dc power plant's accident...
Hoppy
I'm pretty sure there is nothing cosmic about TK's concoctions.  ;D
yfree
The RED device is a very interesting one. It should not be ignored. It is the closest arrangement so far that can work as analysed and proposed by William J. McFreey. The RED arrangement is capable of exciting high speed circular currents in ferrite. The strong ferrite magnets provide both the axial magnetic field (perpendicular to the plane of the magnet) as well as the "fuel" or "gain medium". This seems to be, at the same time,  the closest replication of the SR193 device. It has to be born in mind that, although deceptively different in appearance, the devices by Kapanadze, Mark, SR193, Magnacoaster... share the same working principle. They draw their energy from material transmutation, which is initiated (stimulated) through Nuclear Magnetic Resonance (stimulated beta decay).
I would very much encourage reading and understanding the invaluable resource provided to the community by William J. McFreey (PJKBook, chapter 3, page 3-135). It is extremely important to understand that without "fuel" or "gain medium", there will be no extra energy generation. In this respect, ideas, and devices built on the ideas that do not explicitly specify the energy source, will not work. They will be "promising", "almost there", but always less than 100% efficient.
