0 Members and 223 Guests are viewing this topic.
forest
Quote from: elementSix on December 11, 2012, 04:03:16 PM
This is a great but simple video of a series, and I finnally see what we need to do to the molecules of the atoms we need to excite.  It's called PRECESSION in NMR..  We nned to find the right pulse to get the atoms on their AXIS andspin them at the same time.  NMR finnally explains what I have been trying to understand about this process.  He explains it in a very simple way and the pulse I believe is used to get the atoms on their axis while also spinning them which causes torque and when they push back(I'm trying to interpret whats going on) they create PRECESSION and release the FREE INDUCTION DECAY that releases electrons..  Everyone can help themselves by reading on what I posted before and watching these videos..
http://www.youtube.com/watch?v=7aRKAXD4dAg  >>>>This is 1 of like 10 videos on youtube that help explain this NMR DECAY THAT WE WANT TO HAPPEN SO WE CAN COLLECT WHAT COMES FROM THE DECAY>>>>  WE NEED TO BE CAREFUL OF WHAT WE CHOOSE TO DECAY, BECAUSE SOME METALS PUT OFF RADIATION AND OTHER BAD HEALTH RISKS.  THE SAFER METALS WILL JUST PUT OFF THE ENERGY WITH RF INTERFERENCE.
Yup, good path of thinking.
cheappower2012
@Hoppy,if you mean published results from tests, there are none.In the Turkey
video ,current in is measured shown along with current out measurements.Turkey is a high tech country,has no oil,
a device generating
high power would be of great  interest to them,if there was nothing to TK's claims then no company would
give him the time of day.If you need  absolute proof that TK's device works then a trip to
TK is going to be needed,along with correct measurements and checking for fraud.It is very hard to believe
that a Santa Claus looking kind of guy,working in a workshop that looks like a junk shop
could come up with a device that people with a very high education could never achieve so it must be a fraud,this is the thinking of many members here.
Its so simple you would laugh,sometimes simple is very hard.
Qwert
Quote from: elementSix on December 11, 2012, 04:03:16 PMWE NEED TO BE CAREFUL OF WHAT WE CHOOSE TO DECAY, BECAUSE SOME METALS PUT OFF RADIATION AND OTHER BAD HEALTH RISKS.  THE SAFER METALS WILL JUST PUT OFF THE ENERGY WITH RF INTERFERENCE.[/glow]
I guess, this work looks related:
http://purco.qc.ca/ftp/Overunity.com%20-%20Forum%20members/otto/ottos-open-tpu/ottotpu.pdf
Also another one worth to mention:
http://www.nuenergy.org/pdf/GB763062.pdf
elementSix
Quote from: Qwert on December 11, 2012, 08:01:55 PM
Thats very interesting, the fact that if you move the device very far, you'll have to retune the frequency unless you have a good  homogenous  field generator.  The spin echo helps with this and helps align all the vectors of the molecules with an 180 degree pulse just a few moments after the initial 90 degree pulse.  Which creates a much longer rate of decay. Urwin Hawn discovered it in the 1950's U of Illinois..  I'll write more I wrote a much more slimmed down version of the youtube videos on NMR.. The 10 part series is very good at informing on NMR.
In the video he shows how if you change the Magnetic field by putting a metal tool or something near the NMR unit, the spike completely changes and the decay rate practically stops...
dllabarre
Quote from: Сергей В. on December 11, 2012, 03:48:56 PM
TO DLLABARRE
THIS IS RED TOPIC. WATCH VIDEOS !! COIL HAS 3 LAYERS WINDINGS - SIMPLE WINDINGS. YOU CAN TRY TESLA BIFILAR, CADUCEUS COIL, TRIFILAR OR ANY CONFIGURATION. MAYBE YOU GET MORE POWER THAN HE GOT. RED POWER BALANS IS MIN 2:1. ON INPUT 36V, 2.5A. HE WAS LIGHTEN 1KW LIGHT BULB AND 300W. USE THICK MONTAGE PVC CONDUCTOR 2mm-3mm IN DIAMETER. MAKE BAR FROM 10-15 STRONG Ne2Fe14B MAGNETS AND WIND 3 LAYERS OVER (or 4,5,6...). TRY MULLER COILS 3 STEPPED COILS, ALSO TRY DON SMITH COIL, WINDINGS FACE TO FACE IN OPPOSITE DIRECTIONS. CAPACITORS ARE ALL HV FROM MICROWAVE OVEN, DIODE COLUMN FROM КЦ201 RUSSIAN AVALANCHE DIODES. PUT THEM IN SERIES FOR VOLTAGE 25-30 KV. MAKE OWN EXPERIMENTS AND ANALIZE ALL WHAT YOU GOT. DON'T WAIT FINAL SCHEMATIC FROM ANYBODY !!
RED ADVICE. DON'T USE HIGH RESISTANCE (IMPEDANCE) LOAD. USE LOW RESISTANCE LOAD 2BULBS 300WATT IN PARALLEL !!
MY ADVICE.IF YOU WANT TO CATCH OVERUNITY PUMP AS MUCH POWER AS YOU CAN FOR EXPERIMENTS. TRANSISTORS IRFP460 OR BETTER IGBT, SEVERAL IN PARALEL 5-10 PEACES LIKE AVISO DID ON PHILIPPINES. RDS(ON) MUST BE VERY VERY LOW. (0.0XX OR 0.000XX OHMS). ТДКС (FLYBACK) PRIMARY SEVERAL WINDINGS HEAVY COOPER WIRE AS ON SCHEMATIC. TESLA DID IT WITH VERY LARGE POWERS ON INPUT. IF YOU CAN PUMP 1KWATT ON INPUT AND TRY TO GET 100KWATT ON OUTPUT. 90% OF ALL ERRORS ARE VERU LOW POWER LEVELS ON INPUT. YOU CAN'T PUT 1 MICROWATT AND GET 1MEGAWATT. USE ABOUT 300-500 WATTS ON INPUT AND TRIM THE OUTPUT FOR MAXIMUM POWER. THIS RED CIRCUIT WORK. IF YOU GOT 5-10KWATT IS ENOUGH FOR WARMING HOME AND HAVE ALWAYS 100o DEGREES BOILING WATER.
AWESOME!!  :D
Thank you for the information.
DonL
