0 Members and 59 Guests are viewing this topic.
xenomorphlabs
QuoteYou need to know source pictures you posted... Don't believe any schematic from CrazyAlex...
This gay always around this project and posted many pictures and instructions. You posted lot of them... But these pictures not from SR
All the diagrams don´t reflect what is really going on in SR´s or Kapanadze´s devices but people are too stuck in projecting an ordinary transformer into the device that they fail to see the lack of wires.
amigo
Don't bother...
*Everything* came from a Czech patent from 1996 and relates to transmutation of Fe56->Fe54.
Here's the original patent: http://spisy.upv.cz/Patents/FullDocuments/284/284333.pdf
Here's the Russian translation: http://www.001-lab.com/001lab/index.php?action=dlattach;topic=4.0;attach=4112
This appears to be the principle behind it.
The art now needs improvement as we have better materials and technology available today...so everyone hop to it. An English translation of the patent would be a good start...
amigo
Oh how ironic (pun intended), this is both a blessing and a curse.
Yes, it appears we finally have the ever elusive "free" energy, at a cost of the material involved (Iron, Copper, Gold, Aluminium...). But that's not all.
I really *REALLY* think everyone ought to also consider the release of 2 neutrons per every atom of Iron, in this case, and start planning how to shield from it... ;)
tak22
And the Czech patent (Russian translation) says it all comes from the French Meyer/Mace patent  9110472  http://www.overunity.com/index.php?topic=4333.0
circles and circles
tak
baroutologos
Here we are again.
It has been mentioned some pages before (by me) that perhaps a ferro-nuclear resonance process as suggested by Patrcik Kelly (http://www.free-energy-info.co.uk/Chapt3.html - The Michael Meyer and Yves Mace Isotopic Generator)
Thanks, Amigo for the Original Patent document. I translated the doc file with google translator and few questions have in mind.
The patent says that the particular transmutation procedure needs 0.5T core flux density, an elevated temparature (150-1000+ c) and electrical current should flows through it. I do not know if those are pre-requisites or just improvements.
SR's device does not seem to attain 0.5T neither Kapanadze's. SR's core is from ferrites hence no current can flow. Unless, the ferrites create the flux, while there is an iron rod inside the ferrites being wired. (unlikely)
The Spanish Experimenter Setup
By the way, concerning the Spanish experimenter's setup. I tried to step-down my ignition's coil output via a 15mH coil wound on a ferrite ring and using a lower turn winding for harvesting the energy. No luck. i also tried to do the same with the multiple ferrite cores and connecting a bulb at the few turns winding. Nothing.
I realized the obvious. In order to step down 10kV to 12volt needs a transformation ratio of almost 1:1000 (no ringing LC apllied). That means in the Spanish experiementer's setup, in order the spark to bring to full brightness the bulb, it must initiate some short of procedure. Since the transformation ratio of his core would not allow direct energy trasnformation of the HV source.
All i am saying is that mayhaps he is upon something of value.
