0 Members and 165 Guests are viewing this topic.
Zeitmaschine
Quote from: Сергей В. on December 14, 2012, 02:48:58 PM
Ufopolitics
RAW VIDEO, FIRST ROUND...BETTER LATE THAN NEVER...;)
http://www.youtube.com/watch?v=HHeDYP1YWDY
HIS CHANNEL
http://www.youtube.com/user/ufopolitics
TO ALL: COPY AND SPREAD AS MUCH AS YOU CAN ALL OVER THE WORLD !! AND WAIT FOR NEW VIDEO INFORMATIONS HOW TO MAKE AND TRIMM.
NOW 6KWATTS OVERUNITY TOMORROW 6 GIGAWATTS OVERUNITY :)
So now the question is: Will this OverUnity ever go beyond YouTube (e.g. eBay) or will it (as usual) just stay there? ::) ::)
Quote from: truesearch on December 14, 2012, 04:50:43 PM
Do you have a link to the forum where the RED's device is replicated successfully?
Replicated successfully? Does that mean replicated as a self-runner without any Copperfield-effect whatsoever? ::) ::)
Quote from: wattsup on December 14, 2012, 05:39:26 PM
Because they wanted to be more fancy with the Green Box, they really needed to control the AC mains and the bearded guy was doing that and only that. He did not move from his location. Also there was another guy to the left of Temo that never moved from there as well.
Then one more question: When they needed a remote control to switch the AC mains then why not putting this remote control into the green box and connecting it with one of the two visible switches? Would this not be a lot more foolproof?
And another question: The voltmeter connected to the water pipe shows 6.4 volts AC, but it fails to show anything when connected directly to the lamps. If the lamps are connected to AC mains then why can't the voltmeter show the correct 220 volts?
Quote from: elementSix on December 14, 2012, 06:13:02 PM
http://www.abrazol.com/books/signals/  Here is a book on how to make the earth NMR setup.      LISTEN TO ME, ALL THESE LAST POSTS AND PICTURES ARE TO THROW YOU OFF THE TRUTH.  I POSTED WHAT IS GOING ON AND THAT IS NMR.
So the Kapanadze device is a Proton Precession Magnetometer?
Materials not allowed: no ferromagnetic materials under or near the polarization coil and platform.
Hmmm ... I can see a fan, an inverter in a steel housing, a transformer, a knife, a pair of pliers all around next to the TK platform. How can this be? ???
Сергей В.
Zeitmaschine read this patent 10.08.2009
Zubkov Mikhail Viktorovich (RU), Zubkov Aleksandr Mikhajlovich (RU)
SWITCHING METHOD FOR EXCITATION OF PARAMETRIC RESONANCE OF ELECTRIC OSCILLATIONS AND DEVICE FOR ITS REALISATION
Abstract: FIELD: electricity.
SUBSTANCE: in switching method for excitation of parametric resonance and device for its realisation by excitation of parametric resonance of electric oscillations by  switching method, reactive electric power is generated. This event is realised in reactive electric power generator (REPG). Additional inductance coil or capacitor with a certain nominal value of inductance or capacitance versus similar elements of the main circuit is connected in parallel to oscillating circuit at certain moments of time in specified mode with the help of thyristors. It makes it possible to vary circuit parametres (inductance, capacitance, frequency of oscillations, wave resistance) in process of each oscillation, according to algorithm of variation of control voltage sent to thyristors from separate pulse generator (PG) and thus to achieve parametric resonance without functional link of current and voltage amplitudes in circuit with value of control voltage. Stationary amplitude of parametric oscillations is provided with the help of stabilitrons with shunting resistors connected parallel to circuit, which, passing through itself a part of charge that participates in process of oscillation and scattering excessive reactive power, thus, amplitudes of current and voltage are limited within the limits required for circuit serviceability. Functioning of PG is carried out by part of output power of REPG, which provides for complete independence of REPG as source of power supply.
You like switching thyristors so ... interesting circuit for you. And tell all where is hidden OU in this schematic !! :)
Pump the OU up !! :)
Zeitmaschine
Hoppy
Quote from: Zeitmaschine on December 14, 2012, 07:15:52 PM
I don't think that TK used a direct connection of the mains feed to the lamps as this would have been obvious to testers that a 'clean' sinusoidal mains supply was powering the device. The main function of the green box was most likely to chop-up the mains and provide the spark gap for eye candy to mislead. The mains supply needed to be isolated remotely from the demo area whilst the device was not running as the feed wire was supposed to be only connected to ground. Once up and running, any measurements taken with clamp meters would have been rendered inaccurate and could be claimed by TK to be 'free energy'  either being 'sucked-up' from the ground or returning to ground.
As for the device being a Proton Precession Magnetometer -  ???
verpies
Quote from: elementSix on December 11, 2012, 01:54:22 AM
Quote from: verpies on December 07, 2012, 07:47:10 PM
The proponents of 1-wire power transfer should enjoy these videos:
http://youtu.be/_cx-eOUjNPE
http://youtu.be/9tzga6qAaBA
Is there a reason those links are not from youtube.com but from youtu.be/? ???
These URLs are shorter and allow linking into a particular time index of the video clip.
The same NSA front owns both of these domains, so there is no other difference.
