0 Members and 68 Guests are viewing this topic.
Zeitmaschine
Quote from: dllabarre on December 15, 2012, 07:50:09 AM
There is a company in Ohio that now has a kit available to build this asymmetric motor.
Apropos »asymmetric«:
This Viktorovich patent is a very terrific finding! Congratulations! Does anyone have seen this device in action yet?
Basically the patent states about the principle of work: Take a resonant circuit and switch its resonance in dependency of the two half waves. One half wave it has a lower inductivity (or capacity), the other half wave it has a higher inductivity (or capacity). So this will create an imbalance (asymmetry) in the circuit which generates additional energy (if we are lucky).
Could it be that easy?
But I can't see any high voltage or any ground connection there. So could this really be the principle of the TK device or could this be a different principle of work? On the other hand, no one knows for sure whether the TK device really needs a ground connection and high voltage or not in order to work. So this could be worth a try to burn up a few more thyristors ...
But if asymmetry is the key then any asymmetry will do it. Then there is no need for a specific layout of the circuit.
Hence happy switching. I'm still waiting for my thyristors (and the day to laugh). :P
wattsup
Quote from: Zeitmaschine on December 14, 2012, 07:15:52 PM
A) Then one more question: When they needed a remote control to switch the AC mains then why not putting this remote control into the green box and connecting it with one of the two visible switches? Would this not be a lot more foolproof?
B) And another question: The voltmeter connected to the water pipe shows 6.4 volts AC, but it fails to show anything when connected directly to the lamps. If the lamps are connected to AC mains then why can't the voltmeter show the correct 220 volts?
@Zeitmaschine
Finally some good questions as always, without any troll-0-dramatizations.
A) Ever try a remote control for your tv with something blocking the line of sight. It won't work. Ever put something close to a spark gap. This can interfere with your transmission and can even start transmissions without you knowing it. It has canceled by remote control for the TV, started programs on my computer and more. Also, if any "unauthorized" person ever flicked that switch at the wrong time, it would not be good. In a case where that type of power is present, the bearded guy was like the fail-safe interlock.
B) I don't know what you mean. If you mean the 6.4 volts was not there on the ground when the lights were lit, they were, because the black vested guy did check it a second time when the lamps were lit. He tried it again from the water pipe to the radiator ground but we did not see the voltage reading. The translation indicates when he checked it the second time and said "same thing".
General.......
The bearded guy did not move because he used his left foot to stand on the AC hot wire coming in from behind him. Only once during the time TK was giving his grand speech the bearded guy moved but he gave the rolled wire to the other guy that was always there. When he gave that guy the rolled wire, that guy looked at the ground to put his foot on that wire again. Notice how they were all in a group around Temo and the bearded guy. With the bushes behind him and people always to his side or front, no one every went behind them to see that wire. hehehe.
Also, at 27:38 when they finished the last demo and TK said "the device will have a rest" the video then cuts out, then comes back showing Temo having already quickly gathered the ground wires and passing them to the bearded guy that never moved, even though everything was now closing down. (Why was that part cut out?) But, when Temo gathered up the ground wire that he gave to the bearded guy, why did he not just pull the final ground wire completely out of the TK coil since it should have been so easy if the wire just went through the TKc like most of us builders have done. This would have freed up the bearded guy from standing there immobile. It was because they could not just pull it out because that part of the black wire used the two conductors separately so there was another connection inside the TKc as shown in my diagram. hehehe
So the bearded guy was stuck with his left hand holding the wires and then all through TKs grand speech, he still stood there holding the wires. At all cost, they did not want anyone to see in the bearded guys left hand because that is the were the AC hot was spliced in and should anyone see that, automatically they would have suspected something was fishy.
Also, when the black vested guy checked the amperage on the black wire from the water pipe to the device, notice he was always presented the wire that was in between the bearded guy and the water pipe. If they would have presented him the black wire that directly entered the TKc (hence the wire between the bearded guy and the TKc) to measure right there, there would have been no reading of amperage because there would have been two live wires in that part of the black wire. Everything is done for a reason man. Once you realize the real modus, all the events come into focus and start making sense.
@elementSix
Ya, ya, you are still a cool guy and I understand how rough it is. I am not saying NMR is not good, but that it is not TK based. It may have OU potential or not, that I do not know and would never say, do not try. Only that NMR has nothing to do with the TK device.
You show a few videos of this respectable professor showing you a highly sophisticated and tried and true NMR coil, that they have developed over many years of trial and error, and, you are then giving all that credibility to TK and his gang of baffoons that were playing god with so many people in that demo area. Lucky the bearded guy was there and never moved and always checked everyone to be safe.
I did not make the TK videos, dammit. I only analyze it and sooner or later (like 1023 pages later hehehe) things are bound to come into focus.
So then just answer this one simple question.
Q1: If the TK Green Box produced its own energy, then why did it not work well with the radiator ground and it worked well with the water pipe. If both are only grounded to the earth and not to a mains AC, what is the difference and why did the water pipe show 6.4 vac or 64 times more then the norm?
wattsup
verpies
Quote from: elementSix on December 12, 2012, 09:56:23 AM
Watch the 10 part video on NMR and after, you think about it, You'll Laugh...
Many others, including myself, have recommended studying these 10 Magritek videos IN THIS THREAD log time ago.
NMR is real phenomenon and can be achieved on a kitchen table.
The most difficult issue with NMR is obtaining a homogeneous magnetic field in order to get many atoms of the sample/gain medium to resonate at the same frequency and phase.
If the magnetic flux density is not constant within the sample, then the precession frequency will also be different.
Of course the presence of different precession frequencies due to inhomogeneous magnetic field can be mitigated by stimulating the sample/gain medium with many different frequencies at once ...such as nanosecond pulses at low PRF created by DSR diodes and maybe even spark-gaps.
I remind you, however, that achieving NMR is not synonymous with achieving a stimulated emission of beta particles ("beta chain reaction").
Zeitmaschine
Quote from: wattsup on December 15, 2012, 08:44:50 AM
But this is strange: If the Kapanadze ground wire is just a trickery then how does it come that Stepanov demonstrates the same trick? Or doesn't he?
The Stepanov device consists of transformers/coils, thyristors/diodes and capacitors connected to an inverter and a battery. Now assumed no one has tampered with the inverter that means the red and the black wire of the inverter (and the battery itself) are completely insulated from the 220V circuit. Then how can the single white wire (leading from the box to the battery) carry 8.2 amps without a closed circuit?
If the Stepanov battery device is also a trick (although it is not even near to a water pipe or a suspicious mains cable), then I fail to understand the purpose of this strange trickery. If a one-sided current is not possible at all then what is the point here in claiming it is possible?
Can we afford to dismiss the TK and Stepanov devices as fakes without any hard evidence that they are indeed fakes?
verpies
Quote from: Zeitmaschine on December 13, 2012, 05:50:47 PM
So Kapanadze has a computer in his box to tune the coils automatically between 60–1000 MHz?  ??? ???
Naah, it's much easier to generate all the needed frequencies at once.
Also NMR precession frequencies of copper, zinc or iron do not approach 1000MHz even in magnetic fields of the strongest NdFeB magnets available today.
In fact these frequencies are in kHz or low MHz range for  those gain media immersed in magnetic fields created by ceramic magnets or those helical coils with few Amps flowing through them.
