0 Members and 171 Guests are viewing this topic.
qwekw
Khwartz
Quote from: forest on December 19, 2012, 04:22:27 AM
There is no point for discussing possible hoax in this thread  >:( If you don't believe TK device is real then fine, but inventing more and more conspiracy theories wouldn't help.
Only truth, help! And knowing what doesn't it's alredy knowing more on what could work :)
Khwartz
Quote from: bass on December 19, 2012, 05:23:07 AM
http://www.youtube.com/watch?feature=player_embedded&v=guWga5Q6Dxo
Power supply 220 through a step-down transformer. As I plan to use a current transformer toroidal transformer 220/12, with the winding 220 is closed and only use 12 volt coil.
Efficiency determined by the total power in VoltAmperah (and I think it is right, no matter who said it took into account not only the active power without reactive). Ie this is simply multiplied by an ordinary tester readings taken in volts input and output on the amps input and output.
At Stepanova video output was about 9000 VA and input about 3300 VA. Ie Efficiency in his case, it was 272%. What is written on the "machine" is a 1000% efficiency on the active power that I think is wrong because it does not include the reactive power.
Based on the testimony of a video Stepanova in English, the resonance set is not very exact, because the proportion of reactive power at the input is large enough. Power factor is approximately 1264/3322 = 0.38.
Wow! So happy to see that someone here cares about to differentiate reactive power, direct one and power factor.
Indeed, with so many capacitors and coils, your Amps and Volts can go "zero" while still huge unphased current, so completely fack the ratio of efficiency, IMO.
Cheers, Khwartz.
Khwartz
Quote from: sparks on December 19, 2012, 11:25:44 AM
  What is interesting is that in the backyard video the run time when the battery is disconnected is always shorter than when it is running on the battery.  Stivep's demo of the ability of a resonant circuit to "store" power same way.  First thing I noticed.  This ability of a resonant circuit to store energy is a good thing.  You can convert highfrequency low wattage into low frequency high wattage.  A small event happening millions of times a second can power a large event happening 60 times a second.  My little transistor radio tuned to noise keeps on blinking an led once in a while.  Acts as a scource of inspiration.
I don't think so! But I better think that, as I said to Stivep: ordinary meters are not good for high frequencies and need to care about the power factor (as just stated before).
The power remains the integral of the curves (Amps & Voltage): with a same maximum voltage, if you increase the frequency, you increase the power of consumption in a resistive/linear load. If you low the frequency, you low the wattage too. But in coils, I think it could have a great risk that you can increase the power factor and "no more see" some Amps.
For E.M. O.U. R&D, 4 entries oscilloscopes with caring of the reactive power looks to me the minimum required.
Cheers, Khwartz.
elementSix
WOW, MagnaCoaster has finally shipped out a bunch of orders.  How about that.  I mean 4 years to get the "kinks" out.  Or they were buys shitty Chinese parts. They are using huge magnets and specially positioned coils, using Quantum Tunneling effects for the power increase.
http://pesn.com/2012/06/11/9602107_Rasas_Zero_Point_Institute_Announces_Emerging_Generators_Galore/
For those of you into Ionizing air energy, theres a video of a de-ionizing generator.  Doesn't show much thoe..
Thanks for the Link, BASE.  Does anyone else think the translator sounds sexy??
