0 Members and 164 Guests are viewing this topic.
sparks
@hoppy
   Parmetric resonance was utilized by Tesla where he often referred to his secondaries circulating currents or obtaining voltages in magnitudes greater than the line.  The oscillators were run below 10khz to exclude losses due to rf radiation and developed voltages between terminals of millions of volts.  The current as low as possible to avoid resistance losses.  I read somewhere the MT was designed for 80 or so amps at a million volts minimum.  Thats 80millionva which when transformed into 100 volts would yield 800,000 amps.  Thats an 80megawatt transmission scheme and I don't see any plans at Wardenclyffe for engines to convert 80megawatts of fossil fuels to power this oscillator.  I see enough power to overcome losses in the oscillator and bring it up to maximum activity over an extended period of time but not 80megava real time pumping.  Perhaps the receiver oscillators were designed to not dampen the mt oscillations.  In his pump analogy where the Earth is a ballon the mt would increase pressure inside the balloon.  This would force pistons up at the receivers.  The pistons would fall as the mt piston rose.  The pistons falling would be in unison with the pressure dropping in the balloon.  No power radiated as the pistons become extensions of the mt.  They help the MT piston return to it's up position as they go to their down position. This is all good as long as you don't load the receivers.  As you load the pistons you end up damping the oscillations of the entire system.  Whatever work the pistons do is missing in returning the MT piston to top dead.  The only way this scheme can work is if the load oscillators dip below a scalar potential and energy enters the system in proportion to the amount of energy leaving the system in the work performed by the receivers.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
27Bubba
As I have stated a while back, the guy swapping at the bolt was very cautious as he wasn't totally sure that the bolt wont carry any current at that time. Little moisture around it and possibly one uninsulated strand of the hidden hot wire would not be a pleasant experience.. ;)
Zeitmaschine
Quote from: wattsup on December 21, 2012, 12:18:02 PM
So again, for me there is enough probable and real proof to show TK tricked the Aq2. Someone would have to have an identical heater element and a variac to see how much juice is required to produce the same visual red illumination of the elements. But is it not really necessary cause this is how he did it.
And that means? The best thing to do is to close down this thread?
Cui bono?
Hoppy
Quote from: sparks on December 21, 2012, 01:52:59 PM
@hoppy
Thanks for the info sparks but I'm sure this is not the modus-operandi for the Aqua2 device.
Hoppy
Quote from: Zeitmaschine on December 21, 2012, 02:40:08 PM
Cui bono?
Why, just carry on developing your own theories on how you think TK did it supported by video clues like Wotsup has done. We are all entitled to come to our own conclusions. I'm sure this thread can support another 1000 pages!
