0 Members and 178 Guests are viewing this topic.
Zeitmaschine
Quote from: core on December 22, 2012, 07:45:19 PM
I'm sure I missed a lot but no real progress was made.
This is because almost nobody cares on the current page about what was written 10 pages ago, so all this keeps going in circles. But nevertheless some progress was made: The trashcan now is full of theories what the TK device not is. Hence at some point in time there should be only one theory left, and that's what the TK device actually is.
Now, what could be responsible when a coil oscillates at 6000Hz? A rough estimate would be: At the least one capacitor providing a resonance and at the least one semiconductor working as a switching device.
So, what's the average IQ factor in this forum? :(
ramset
Zeits
Ggeeeeze no body told us there was going to be a test !
is this multiple choice?
HHuhboy........
Thanks Grandma
Farmhand
People get confused with power and energy. It can be complicated.
I built this circuit below and made some measurements.
EDIT: (Fixed link, it now shows correct drawing Sorry.)
http://i227.photobucket.com/albums/dd168/Toey1/ArmstrongOscillator111sm.jpg
This pic shows the measurements
http://i227.photobucket.com/albums/dd168/Toey1/Primarymeasurements00555_zpsde001285.jpg
The input was 12 volts at 280 mA =  3.36 Watts
There is no output. But the oscillating power in the primary was 28 VRMS at 5A = 140 var
The peak power in the primary is 46 volts x 14 amps = 644 Watts.
This is not OU it is a magnification of power. There was no usable output when the measurements were made.
What this allows though is the peak power and voltages along with the higher var produce effects not possible with just the 3,36 Watts alone.
By magnifying the power it's more effective for producing certain effects.
Now that is just a 12 volt Tesla coil, imagine one with 8000 volts input and a very high "q". Imagine the oscillating power. Don't try to measure it though.  :o
This video is just a comparison between regular driven fluro tube and an excited one, but at the end about 8:30 there are some interesting effects seen in a 4 foot fluro.
http://www.youtube.com/watch?v=xz_pSsZtUZo
This is the same setup with two receivers connected by the one wire method. Note the input goes down when power is used unless the transmitter is re tuned.
http://www.youtube.com/watch?v=TJd8TNC75AI
The used power is still less than the input though.  The output is the consumed power or dissipated energy from the loads.
The input is the consumed input power or the energy used to make it work. 3.36 Watts is ( I think 3.36 joules per second) input.
Those 8 LEDs were 5 mm LED's and used a tiny current but with good voltage across them, I have some LED boards planned so as to make a proper measurement.
Cheers
EDIT: (First link fixed)
And here is a scope shot but it was probed between the primary negative (mosfet drain) and the circuit ground at a different time. (not relevant to the measurements).
Yellow trace is the drain and the blue trace is a remote probe on the bench about 400 mm from the coil.
http://i227.photobucket.com/albums/dd168/Toey1/ArmstrongOscillatorDrain1.jpg
FreeEnergyInfo
