0 Members and 42 Guests are viewing this topic.
magneto_DC
Quote from: FreeEnergyInfo on December 23, 2012, 04:08:50 AM
MUSTAFA FREE ENERGY 2.5 KW
Hi FreeEnergyInfo,
some more questions. :)
2.1. In the middle circuit has to be a condensor?
2.2 The transformer on the right has iron core or air? What is the ratio of the transformer, ~ 30:2000 ?
2.3 Are there two items on the right upper side, or is there only one? Is there a Gas Discharge Tube (GDT)? What are the specifications? Is there a diode and a Gas Discharge Tube?
Tank You
magneto_DC
Zeitmaschine
Quote from: verpies on December 24, 2012, 03:47:27 AM
For example the confinement of charged particles (not conduction electrons) inside solid matter requires higher magnetic flux density for smaller radii (see the attached photo of electrons in gas being confined to a circle by a magnetic field).
Also, smaller radii lead to higher resonance frequencies and higher frequencies incur higher penalty from the skin-effect in conductive materials, possibly bringing the device below the break-even point (unity).
I see. Then this combined with this ...
Quote from: cheappower2012 on December 24, 2012, 05:06:59 AM
The purpose of showing the two devices could easly be faked was to remove them
from the list of working tpu's to find a common link between the real tpu's,this is to understand how this device works,
all real tpu's have common things.
Sm is very good at hiding things so the tpu is as hard to figure out as is TK's device.
... means that there is no solid proof that the smaller SM devices are fake. It is one more time an assumption based on a video analysis that it could be a fake because of some »holes« in the video.
Now what if SM thought he has proven his big device beyond all doubt to be real, so he simply did not care for a watertight video when he presented the smaller devices?
Quote from: cheappower2012 on December 23, 2012, 06:07:41 PM
reading for a load 120 watts is the same as no load
Yes, strange thing. But the stranger thing is that at 4:22 in the video SM points out this fact explicitly. So why should he do that if this behavior is just due to a hidden battery in the faked device?
What if this device simply does not behave like an ordinary transformer, therefore the output voltage stays constant regardless of the load (at least up to a certain point)?
Just considering all possibilities ...
Khwartz
Quote from: Farmhand on December 23, 2012, 01:23:46 PM
Thanks  Khwartz, But I am very much a learner and always will be.  :) Although I am trying to make good measurements
and use correct terms I am still quite prone to mistakes and do appreciated being corrected, it would be difficult to learn if I can't accept corrections.
QuoteI don't have much money and my equipment is a big investment so I must take it slow and learn how not to ruin the expensive equipment.
Understand!
QuoteOne reason why I made the small Tesla coils so tame ie, 10 primary turns. This allows me to scope it without too much chance of damage.
I'm interested to move to using a Valve (vacuum tube) to run my larger coils in continuous wave mode so the small mosfet circuit was so I could learn some stuff about
feedback oscillators mainly, The road is long and I'm too old to hurry.  ;D
Looks good plan (but be careful for possible X-Rays from vacuum tube, ant way, a simple aluminium sheet is enough to make a good screen, as I could know.)
QuoteWhile I'm waiting for LED's
IMO, you should be careful with LEDs if you use them as loads to evaluate the output power, Farmhand, pure linear receptors like resistors looks to me the only way to not miss interpret what is going on, with always 4 entries oscillo for amps and voltage, power factor measurements and so on.
Graphs of the evolution of each parameters in experiments, in my viewpoints are mostly efficient to help to detect, to spot any relationship and anomalous phenomenon by spotting possible the synchronism of events and very important: to log the set of your experiment.
Quotei'm thinking I will setup the two identical transformers as twin transmitters each with it's own oscillator but both connected by the secondary bottoms to
a big ground plane. I hope this will produce "beats", I will try first just powering one and letting the other oscillate on its own, but I think if both were powered it could be better.
I should be able to tune them so that I can change the frequency of the "Beat" I want it to be a low frequency beat less than 5 kHz I hope.
OK, Framhand, here are links that should interest you to economise time and efforts. They are the most serious and advanced E.M. Free Energy seekers I've found until now on the web; if it help you in any way, please Framhand, just let me know:
1.1 http://www.overunity.com/profile/konehead.26038/area/showposts/#.UNhlxqzg_Ak
Doug (konehead) is very familiar with F.E. seeking having personally known Hector Perez Torres for example, the inventor of the Rotovertor (dynamic device) and the Transvertor (static device). konehead is very about dynamic devices but you can PM him I think any time to get some help and advises.
1.2 http://www.youtube.com/watch?v=Q1SNYAoEak0
1.3 http://www.youtube.com/watch?v=fxbigmtDVPc
2.1 http://www.youtube.com/watch?v=ZPkavx1BZpo
Kurt (kdkinen) works on Don Smith device mainly but has try to integrate Thane Heins technology with interesting effects (that was my advise ;) ).
3. http://www.youtube.com/watch?v=48wSIsb6IeQ
Selfonlypath (I don't give his first name for personal life protection), knew Hector too. He is a true technician of electronics.
QuoteThen I'll see what happens as far as making ground disturbances goes and other experiments.
To all, rest assured if by some chance I find something that is or even looks like OU (anomalous energy) or I think could lead to OU I will share it to the best of my ability.
I think you will enjoy (despite our very bad french accent ;) ) the vids series of Selfonlypath.
I have neither place nor time to replicate and test, so very nice if you can do yourself and report your results ;).
Note he very looks like to have now seriously achieved in the most professional way O.U. by capturing exceeding energy in plasma globe (the "ideal spark gap", form my own personal viewpoints ;) ) by his (?) "phantom diode effect".
QuoteI couldn't afford a patent even if I had something and wanted to patent it so I'm all open source. Money is not nutritious to eat and is toxic to burn for heat, at any time it could be just paper or plastic.
;) But it can help to achieve things as an energy to produce things and to distribute them :) I do not believe that without industry, a F.E. system will have any true large diffusion but only for aficionadi  :(
QuoteCheers
Cheers too.
Khwartz
To all!
IMHO, as Wattsup, I think that IF a F.E. seeker is true AND claims for humanity gift, if he is not perfectly clear and transparent with what he shows, he is a fake in himself, so his product too very very probably.
Aside to this, you have guys who do the exact opposite, having or not good results. Still IMHO, it can be only more efficient to focus on these last guys than on the first ones.
Any way, O.U. devices do exist and work, but not all inventors are interesting to lose all the benefit of their costly researches both financially and in time often taken on personal life. For me, it is even a negative principle to not mostly rewards those who could help others lives while producing devices and services that really help the Community and anyone to survive and we would do much better while creating an international independent foundation free energy sponsoring sustained by all free energy seekers.
Cheers, Khwartz.
FreeEnergyInfo
MUSTAFA FREE ENERGY SCHEMATIC ....
www.freeenergylt.narod2.ru/anonimus_free_energy/
tc 270 transformer ....
www.vprl.ru/index/transformatory_ts_270/0-83
народ помогите перевести аудио фаил на англыски йазик ..
йа нимогу сам ето сделат .
ниумейу хоросо англыски ....
спасибо...
http://yadi.sk/d/YrVr9l7A1O5iG
people help to translate the audio mp3  file englix ..
ya nimogu himself UTB sdelat.
niumeyu Khoros anglyski ....
thank you ...
