0 Members and 83 Guests are viewing this topic.
Mr_Video
Quote from: markdansie on July 03, 2009, 06:36:05 PM
Mr X pointed out several things in the video which gave a very plausable explanation of where the energy came from. I know seveal of you will dispute this...and good reason to. However it has raised enough doubt in my mind that I would want to see the device in a controlled enviroment.
The theory is they are harvesting EMF from power lines located nearby. I always remeber seeing an artist in England who use to place fluro tubes in the ground under power lines and they use to light up.
I have attached a file worth reading writen by MR x (who I believe is Russian)
Kind Regards
Mark
EXACTLY what I have been thinking about for the last couple of days !
back at the turn of the last century, when Nikola Tesla built his energy transmitter, there was no electrical grid as it exists today, for his wireless transmission of electricity to work, he naturally needed an energy source .
today, with all the hi-tension powerlines strung all over the place and carrying as much as 120Kv, it's possible that all Kapanadze needs is the receiver now, and that device does look like Tesla's design.
more research should be done, but it could be that all Kapanadze may have done is invent the electric equivalent of Napster   :D
hartiberlin
@markdansie
you are totatly wrong with your assumption,
that this is stealing power from a 220 Volts 50 Hz grid !
This just does not technically work with this small setup
at these shown power levels !
Your friend Mr.X did not watch the videos carefully ..
Pirate88179
@ Mark:
I am glad you spoke to your friend about this and shared what he had to say.  Since most of us on here have been "Mylow'd" before, I think it is good to be aware.
Having said this, I agree with Stefan.  Not because of the technical issues involved as I have already admitted they are beyond me at this time, but because this fellow received some patents on this.  I know this is not evidence by itself, but I would like to think that their patent office would have someone there that would look at this and be able to say.."Hey, this guy is just tapping into the grid emissions."
I know folks have received patents on things that do not work but, this is the exception and usually not the rule.  I made no claims on the validity of this when I posted the video and I still don't, but, with all of the good minds here I am sure we can figure it out one way or the other.
Thank you for bringing this to our attention, as I said, it is good to be aware.
hartiberlin
Well, I just had a look at the DOC File Mr. X has put together.
Here are the 3 most important pics attached.
This is total nonsense and never could extract 5 KWatts with this setup.
If the used water pipe would be so hot that there could be extracted
5 KWatts, the guy attaching the cable would already be dead !
Also the first picture with the red copper cable  makes no sense,
as the copper wire is more conductive than the load resistor and
Kapanadze only used ONE ground connection, not 2 in the video.
Also lighting up fluorescent bulbs via 50 Hz EMF radiation is
totally different than to light up 5 KWatts of incandescent bulbs.
Fl tubes light up because of the high voltage differential  field potials under
380 KVolts lines, but not because of high amperage currents...
But here we have high amperage current in incandescent filament bulbs !
The only theory I can accept is the following, that Kapanadze is able to
tap the ground return currents from 50 Hz ground currents somehow.
Every grounded house has failure and bad isolation currents going back via the
ground to the power stations.
The ground is always very conductive , only around a few Ohms resistance.
Therefore all different 50 Hz currents flow through the earth back to power
stations.
If he succeeded to tune his LC circuits to these 50 Hz ground circuits
or an harmonic of it and just excites his LC circuits with a harmonic
of 50 Hz via a sparkgap discharge pulse, he might be able to put his
LC-tranks into resonance with these flowing 50 Hz ground currents
and this way "attract" these 50 Hz waves into his circuit and use the resonance
transformers to extract the resonance energy into his  incandescent bulb loads.
But the way Mr. X has shown it will never work with the devices shown in the videos
to extract 5 KWatts of power from these small power lines.
Regards, Stefan.
hartiberlin
@All,
use a NON Grounded scope and put just the scope head
pin to your
waterpipe or heating pipe in your house without using the negative ground
connector of the scope head.
What will you see on your scope ?
Big 50 or 60 Hz sine waves from the ground "failure currents" going back to
the power station !
This is what you can tap if you have the right circuit and this is
what Kapanadze is doing !
Or maybe he is also tapping other higher frequency currents that
are still in the ground.
This is probably much more related to the things Nathan Stubblefield did with his AC extracting earth batteries
via "special coils" in the ground.
