0 Members and 665 Guests are viewing this topic.
elementSix
Quote from: zcsaba77 on January 19, 2013, 11:48:54 AM
.... and someone know about Kapanadze '2 disk' motor/generator? did someone replicate it?
Thats the Faraday Dynamo.  Peter Linddemin replicated it.  All you have to do is spin a copper disc at a few thousand RPM's in a magnetic field and with the contacts on the outer edge of the disc and the other on the disc at the shaft and you get high amps but little voltage.  Like 3 or 4 volts.  The shaft is not magnetic.  Farday used magnetics placed at right angels to each other on both sides of the disc.  4 per side each facing N,S,E and west...  TK used steal disc with a coil on the shaft between them and that created the magnetic fields..
zcsaba77
Quote from: elementSix on January 19, 2013, 02:18:10 PM
Hi
I find info about this dymano (here: http://www.free-energy-info.com/Chapter3.pdf on 141 page), but I not sure it is correct, because I not see on Kapanadze's dynamo any coils on end shaft, and Im not sure he used non-magnetic shaft, I watch so many times that video, but just saw big ferrite ring placed on end shaft, and I cant understand what does to motion/spin, if he build like on 141 page, under coil middle two disk is magnet ring or rings, initial magnetic orientation is axial, I saw so many videos where playing magnets in toroid ferrite core coil, pulsing by DC voltage, but newer see shaft, I mean magnet ring on shaft, what does dc pulse torroid with the shaft, I have not equicment try this
verpies
Quote from: zcsaba77 on January 19, 2013, 03:18:40 PM
If there is any truth to Kapanadze's devices then the principle described in this document is the one that makes the most sense.
Anyway, there is not much sense to study the data coming from Kapanadze because he is secretive if not deceptive.
The inventors of Yoke device were much more forthcoming (scopeshots, spectrograms) and the proof that this device indeed was OU was much better than with TK's devices.
NickZ
   Verpies:
   Can you post a link to any videos that may be available showing the "yoke device" that you  are mentioning.  Or where to find more info about it.
  Here is a picture of my dual inverter set up. Also a picture of the crt monitor yoke that I've rewound with dual secondaries. In the first picture, both inverters are join in parallel at the 12v -24v input, as well as being joined and connected by their secondaries. I use a Cfl bulb between the different secondary coils (not shown) to separate them from making direct contact. It works this way even though the Cfl that is used does not light, it makes the two devices work to gether more efficiently than if not joined together.  Earth ground is also used.
I use solar panels as their input source, wall adapters, or 12v batteries.
  I would like to build a Kapanadze type device, especially one using the yoke cores, as you've mentioned that they have had some good success.
Any info would be appreciate.
                                             NickZ
cheappower2012
@Hoppy
Well I believe TK is using tricks not to create an effect thru illusion but to hid the
operation and construction
of the device.As to evidence presented by wattsup,when he can't figure out something he
looks for anything to discredit.Presented evidence as such is not absolute proof,the problem is there are many variations
of the TK device,you have to assume everybody that seen the device is a fool including the Turks.
when its known where the mains are in the Turkey video,TK could not fool the Turks by that means,In my opinion
the way he faked them out was like this,only whats in the metal boxes is the device,the device is very simple
when TK decided to tell theTurks to goto hell,he never intended to give them anything,only rip them off,he simply opened the boxes and rerouted the
connections,the device after that was nonworking the Turks could not figure out how to get it working.
