0 Members and 478 Guests are viewing this topic.
xenomorphlabs
The spark gap in Kapanadze´s small device makes no sound at all as well as in SR´s set-up. It is being speculated that that is due to the signal being modulated (AM or FM) as in a singing arc for example and also "maybe" higher than 15 kHz to be inaudible.
The guy that made the video is probably on a good track though.
forest
Quote from: xenomorphlabs on April 30, 2010, 09:01:39 AM
Good point. The part of solution is surely to generate ARC not spark ! Spark is AC oscillation with wide range of RF radiation, arc is unidirectional energy transfer , no heat , no sound, no large light. Then find a circuit potential and adjust ARC length to make it always disconnected from both ends before magnetic field collapse.Then Ambient background response happen.Iron or ferrite is only used as delay line so low frequency can be used. Clear and plain Don Smith lecture.
Goat
Would an Arc converter be related to the above discussion as far as using the arc and frequency?
http://en.wikipedia.org/wiki/Arc_transmitter
"The arc converter, sometimes called the arc transmitter or Poulsen arc after its inventor Danish engineer Valdemar Poulsen, is a device that used an electric arc to convert direct current electricity into radio frequency alternating current. It was used in radio transmitters for a short period around 1920 before it was replaced by vacuum tubes, and was one of the first technologies that was used to transmit sound (amplitude modulation) by radio. It is now on the list of IEEE Milestones as a historic achievement in electrical engineering."
Regards,
Paul
xenomorphlabs
That whole arc thing is probably only intended to get the magnetic domains into a state where they would "accept" free oscillation better.
Think of it as an "ALL-IN-ONE" Floyd Sweet Device.
Assuming the transistors are being run at 10 Volt, there has to be
a mechanism that gets the voltage up to 220 Volt.
Since there is not enough wires to do that with the classical inverter set-up
it seems that only a high-q resonance could achieve that or just a simple
Sweet secondary.
The arc is just "ringing the bell" then.
baroutologos
Xeno,
*In the bottom line should happen something like that. But, there is not a single clue in scientific literature mentioned that this result can be produced.
The thing with this device, is apart from the ground breaking method of energy production is that introduces novel scientific knowledge.
If you think about it there is no a solid evidence so far to allow any particular optimism.
*Assuimng it is true
