0 Members and 503 Guests are viewing this topic.
Hoppy
Quote from: forest on January 23, 2013, 10:06:20 AM
Meanwhile , with a cup of good coffee think  about those questions :
can you imagine resonant circuit with no reactive power ?
can you question or/and proof whenever field is weak or simply balanced ?
can you see that Newton third law is the most basic and apply everywhere ?
can you understand that even the most extraordinary quantum effect can be shown with simple device  (world is proportional and if there is a complex device with simple principle there should be a simple device with complex principle behind) ?
can you see a process of unidirectional energy transfer which do not break Newton III  law?
can you explain why Earth rotate ?
Wrong thread for discussing these questions!
Hoppy
Quote from: Zeitmaschine on January 23, 2013, 08:35:35 AM
On the other hand a thyristor of the kind used by Stepanov is not the type that is normally available in the junk box of a tinkerer. Means since Stepanov obviously had to obtain his thyristors for switching it is not far-fetched that Kapanadze also had to obtain his triacs for the same technical reason, although it is more likely that such triacs can be found in a junk box.
What type of thyristor did Stapanov use?
Zeitmaschine
Quote from: verpies on January 23, 2013, 10:26:46 AM
Earth rotates because of inertia.
But how (or by whom) was this rotation started in the first place? ???
Quote from: Hoppy on January 23, 2013, 10:51:54 AM
A blurry type of thyristor. :D
The best match I could find is the Soviet T160.
BTW: In front of the four thyristors there are two capacitors on the table connected with a cable. Interesting.
NickZ
  Thanks for the offers guys, but I don't have a scope, nor a signal generator. Both being essential to tune the circuit properly.
   I am not looking to get OU, but an efficient circuit to run off of solar panels, that will help increase light output, over what just conventional solar power can provide.
Is there a diagram of the yoke device that can be downloaded?
