elementSix
How does Tariel Kap.  Keep resonance between his primary, secondary.  He used some kind of PLL?  If you can't adjust the  frequency and phase of the BB loop 7 and 8 (primary and secondary), then you need to adjust the frequency and phase of the transmission "station" (inductor).  Hey FREEENERGYINFO, can you translate these Pictures? Here is the page they are on.
http://halerman.narod.ru/TTCG/Kapanadze.htm
FreeEnergyInfo
Quote from: elementSix on January 29, 2013, 03:53:31 PM
SORYYY... NO ...
MINIMUM ENGLIH ....
Zeitmaschine
Since I'm currently waiting for some ordered electronic parts, in the meantime more theoretical considerations, because in theory it always works:
What is the purpose of TK's blue inverter?
1) To provide continuous electric energy to the device?
Can't be, because a circuit that generates electric energy by itself should not need the continuous supply of electric energy from the outside.
2) To provide 50Hz?
Can't be, because a circuit that generates electric energy by oscillating at its own resonance frequency should not need the supply of 50Hz from the outside.
So what does that mean? Does that mean the purpose of the blue inverter is once more just distraction and the green box device could be started with the pulse of a 9V battery as well?
Something oscillates and resonates and generates thereby energy. Now what is the standard circuit to get oscillations? It is the Astable Multivibrator or Flip Flop circuit. Thus what could happen if one replaces the transistors by thyristors (triacs) and the resistors by coils (50Hz transformer) so the current in the circuit is AC instead of DC? Could it be that this leads to a parametric oscillation that keeps oscillating even when the start-up pulse has been removed? Just asking, because such a construction would fit very nicely the Steven Marks TPU, which clearly runs without sophisticated electronics for pulse generation (presumably like Kapanadze and Stepanov devices). And it would fit this droll statement, it need a little bit polishing, it is close.
So who would like to do the polishing? :)
FreeEnergyInfo
elementSix
Free Nonsense..  I like that.  TK has to have a circuit controller to adjust the input to keep resonance.  Resonance in Resonance.  Whos schematic is that Flyback??  What do you think of using a PHase Locked Loop to adjust the input?  Does that make sense?  The Tk device is basically the Tesla Magnifying Transmitter.
Tesla Wrote
In Fig. 1, A designates a primary coil form­ing part of a transformer and consisting gen­erally of a few turns of a stout cable of inap­preciable resistance, the ends of which are connected to the terminals of a source of pow­erful electrical oscillations, diagrammatically represented by B. This source is usually a condenser charged to a high potential and dis­charged in rapid succession through the primary, as in a type of transformer invented
by me and not well known; but when it is de­sired to produce stationary waves of great lengths an alternating dynamo of suitable con­struction may be used to energize the primary A. C is a spirally-wound secondary coil with­in the primary having the end nearer to the latter connected to the ground E' and the other end to an elevated terminal E. The physical constants of coil C, determining its period of vibration, are so chosen and adjusted that the secondary system E' C E is in the closest pos­sible resonance with the oscillations impressed upon it by the primary A. It is, moreover, of the greatest importance in order to still further enhance the rise of pressure and to increase the electrical movement in the sec­ondary system that its resistance be as small as practicable and its self-induction as large as possible under the conditions imposed. The ground should be made with great care, with the object of reducing its resistance. Instead of being directly grounded, as indicated, the coil C may be joined in series or otherwise to the primary A, in which case the latter will be connected to the plate E'; but be it that none or a part or all of the primary or exciting turns are included in the coil C the total length of the conductor from the ground-plate E' to the elevated terminal E should be equal to one-quarter of the wave length of the electrical disturbance in the sys­tem E' C E or else equal to that length mul­tiplied by an odd number. This relation being observed, the terminal E will be made to coincide with the points of maximum pressure in the secondary or excited circuit, and the greatest of flow electricity will take place in the same. In order to magnify the electrical movement in the secondary as much as possible, it is essential that its inductive connection with the primary A should not be very intimate, as in ordinary transformers, but loose, so as to permit free oscillation — that is to say, their mutual induction should be small. The spiral form of coil C secures this advantage, while the turns near the primary A are subjected to a strong inductive action and develop a high initial electromotive force. These adjustments and relations being care­fully completed and other constructive fea­tures indicated rigorously observed, the elec­trical movement produced in the secondary system by the inductive action of the primary A will be enormously magnified, the increase being directly proportionate to the inductance and frequency and inversely to the resistance of the secondary system. I have found it practicable to produce in this manner an electrical movement thousands of times greater than the initial — that is, the one impressed upon the secondary by the primary A — and I have thus reached activities or rates of flow of electrical energy in the system E' C E measured by many tens of thousands of horsepower. Such immense movements of electricity give rise to a variety of novel and striking phenomena, among which are those already described.
This is Sited in TK Patent.  Would this be just the transformer for output or input??
Converter wherein a piezoelectric transformer input signal is frequency modulated by a pulse width modulated signal
PATENT--EP 0758159
HEY ZEIT,  That Multivibrator, is like like a PLL??  That makes sense that it would need one for adjustments, Like the spark gap is only on when the coils get out of sync.  That why it doesn't stay on all the time..
