dllabarre
Quote from: FreeEnergyInfo on January 30, 2013, 03:18:31 PM
SHEM...
Thank you for the image.
What forum did you get this from?
I checked all the forums I know in Russia and couldn't find this image.
DonL
xenomorphlabs
I'd like to point something else out in Tesla's text:
Quote from: elementSix on January 30, 2013, 06:19:25 PM
This relation being observed, the terminal E will be made to coincide with the points of maximum pressure in the secondary or excited circuit, and the greatest of flow electricity will take place in the same. In order to magnify the electrical movement in the secondary as much as possible, it is essential that its inductive connection with the primary A should not be very intimate, as in ordinary transformers, but loose, so as to permit free oscillation —
Imagining electrical movement.
He did not use the word current, but it seems that's what he refers to.
So magnification of current which is comparable to Kapanadze's current amplifier ...
Farmhand
Free Nonsense..  I like that.  TK has to have a circuit controller to adjust the input to keep resonance.  Resonance in Resonance.  Whos schematic is that Flyback??  What do you think of using a PHase Locked Loop to adjust the input?  Does that make sense?  The Tk device is basically the Tesla Magnifying Transmitter.
Tesla Wrote
In Fig. 1, A designates a primary coil form­ing part of a transformer and consisting gen­erally of a few turns of a stout cable of inap­preciable resistance, the ends of which are connected to the terminals of a source of pow­erful electrical oscillations, diagrammatically represented by B. This source is usually a condenser charged to a high potential and dis­charged in rapid succession through the primary, as in a type of transformer invented
by me and not well known; but when it is de­sired to produce stationary waves of great lengths an alternating dynamo of suitable con­struction may be used to energize the primary A. C is a spirally-wound secondary coil with­in the primary having the end nearer to the latter connected to the ground E' and the other end to an elevated terminal E. The physical constants of coil C, determining its period of vibration, are so chosen and adjusted that the secondary system E' C E is in the closest pos­sible resonance with the oscillations impressed upon it by the primary A. It is, moreover, of the greatest importance in order to still further enhance the rise of pressure and to increase the electrical movement in the sec­ondary system that its resistance be as small as practicable and its self-induction as large as possible under the conditions imposed. The ground should be made with great care, with the object of reducing its resistance. Instead of being directly grounded, as indicated, the coil C may be joined in series or otherwise to the primary A, in which case the latter will be connected to the plate E'; but be it that none or a part or all of the primary or exciting turns are included in the coil C the total length of the conductor from the ground-plate E' to the elevated terminal E should be equal to one-quarter of the wave length of the electrical disturbance in the sys­tem E' C E or else equal to that length mul­tiplied by an odd number. This relation being observed, the terminal E will be made to coincide with the points of maximum pressure in the secondary or excited circuit, and the greatest of flow electricity will take place in the same. In order to magnify the electrical movement in the secondary as much as possible, it is essential that its inductive connection with the primary A should not be very intimate, as in ordinary transformers, but loose, so as to permit free oscillation — that is to say, their mutual induction should be small. The spiral form of coil C secures this advantage, while the turns near the primary A are subjected to a strong inductive action and develop a high initial electromotive force. These adjustments and relations being care­fully completed and other constructive fea­tures indicated rigorously observed, the elec­trical movement produced in the secondary system by the inductive action of the primary A will be enormously magnified, the increase being directly proportionate to the inductance and frequency and inversely to the resistance of the secondary system. I have found it practicable to produce in this manner an electrical movement thousands of times greater than the initial — that is, the one impressed upon the secondary by the primary A — and I have thus reached activities or rates of flow of electrical energy in the system E' C E measured by many tens of thousands of horsepower. Such immense movements of electricity give rise to a variety of novel and striking phenomena, among which are those already described.
This is Sited in TK Patent.  Would this be just the transformer for output or input??
Converter wherein a piezoelectric transformer input signal is frequency modulated by a pulse width modulated signal
PATENT--EP 0758159
HEY ZEIT,  That Multivibrator, is like like a PLL??  That makes sense that it would need one for adjustments, Like the spark gap is only on when the coils get out of sync.  That why it doesn't stay on all the time..
Hi, the part in bold (in my opinion) describes a magnification of power, and does not describe more energy utilized as is input by him.
The magnification of power is no more free energy than the magnification of light by a magnifying glass. The light from an area is concentrated and focused
so as to increase the energy to certain area by concentration, the magnifying glass also casts a shadow where the light is taken away from. The bigger the magnifying glass
does not necessarily mean more magnification, it's more to do with the magnification factor of the lens and the focus (tuning).  A magnifying glass does not emit more light energy than it takes in, it just concentrates and focuses it, to do more effective work.
Power is not energy utilized. In my opinion he is describing an accumulated oscillating power.
Cheers
Hoppy
Quote from: Farmhand on January 31, 2013, 03:52:38 AM
Cheers
Could 'movement' be a term Tesla relates to current here. A magnification of current through transformer step-down from high to low voltage?
jbignes5
In simplist terms lets try this analogy. You have a pile of gun powder on a table. You light it an poof it instantly flashes and a puff of smoke follows. Now take that same powder and now put it into a brass closed ended sleeve. aka bullet casing. Now light the powder with a lead bullet pressed into the other end. You have now taken all that expansion of the powder and magnified the force by constriction and applied that force to the lead bullet. In a sense the constriction magnifies the force upon the bullet and a massive external force is magnified upon the bullet. The magnifying force can improve the force or make it measurable, when the pile on the table could not have been measurable or useful for anything but flashing, gas expansion and smoke production with some heat thrown in there. The casing and pressed bullet into that casing cause a magnification of all of those forces and applies it to the lead clogged end allowing all that force to be efficiently applied to the bullet.
Magnification is in this sense a concentrating and redirecting aspect as farmhand has pointed out. Is this usefull? Without arguing about what the magnification is of, I'd say YES?
So now lets look at Tesla or TK's magnification. If you had a weak force you could channel and control in your device, how could you make that usefull? Lets look at an amplifier. We take a weak control signal and control a massive power with that weak control. That in a sense is a magnifier. Exactly the same as the analogy of the sun through a magnifying glass. We make usefull a Vast weak force and concentrate it to do more work then could be possible with the weak force. Plain and simple.
In both cases the massive weak force area are condensed or magnified upon the area we choose to get the amount of force we want for useful work.
The opponents will always argue semantics ignoring the context.
Lets argue instead what is a spark or arc.
Having two elements, one charged in close proximity to each other will always spark or arc to satisfy that charged end. Meaning something moves twords the charged end. This something involves light and heat as it discharges to fulfill the charged end. This is the free in this instance. Whatever jumps that gap and fulfills the charged end is the response that is free. Whatever this is it emits light and heat across the gap. If we use the analogy of a vast capacitor like the ground then we can see that there will be two movements. One twords the charged element and one back twords the capacitor to fullfill what was borrowed. Two movements for the price of one. Both of which emit fields. Both of which can be harvested and magnified.
Now lets replace the ground with a capacitor. Can you see where this is going? I have ignored a lot in this process like fields just to keep it simple but it is all relevant.
Light and heat have both to do with magnetic and electric fields combined.
