0 Members and 36 Guests are viewing this topic.
elementSix
Here is the paper with Teslas work in it.  I got that info from earlier.  Its from a patent I believe..
READ IT.  I skipped a lot of good info..
SRRY, I posted the right Txt now..
jbignes5
Quote from: elementSix on January 31, 2013, 12:15:01 PM
Now there is a problem of all the question marks in that text file. What are they after the text of the original Tesla patent?
jbignes5
How I see TK's system is now a high voltage(electric field) coil (thick copper coil=Upper atmosphere) with the earths crust (Ground Wire) acess to the ground currents and the extraction coil in between each. Resonance can be applied to each coil via construction and the ground current is drawn into the circuit via the pickup coil. It is then used to strengthen the fields then returned via the load to ground.
Hoppy
Quote from: elementSix on January 31, 2013, 11:38:03 AM
When Tesla says he gets HORSEPOWER from this, That would have to be Current, Right?  I mean without current you don't have much use with a large Electric Motor.  You need Current for the Horsepower to move the motor.  Those big motors back then probably used a lot of current... ??
I agree, this is my thinking. His 'Movement' = current, whether it be from capacitor discharge or other source.
jbignes5
Quote from: Hoppy on January 31, 2013, 01:03:15 PM
Ok you use the word current.. What does that mean to you? How is current initiated?
In my world current is initiated from a potential difference. Because potentials like to equalize when a path is put between them, this action is deemed current. Current is potential satified or equalized. What current is, is the issue here. What is moving so that potentials can be equal?
This goes into matter and what it is. From my understanding matter is bound charge. It is bound by matter and held into that charge by the capacity of that binding. These charges are highly mobile and the only influencing of that charge is by the electric field. Unbound charges are free to mobilize in a very short time. This is the effect of corona discharges. The potential is fulfilled by charges that are attracted to the potential. The charges move so fast that they create light in the process causing the effect we see in a corona discharge. Since matter has mobile charges bound inside of it they can move as well but it takes more potential to move the charges out of that binding container of matter. When it is taken from the matter it creates a vacuum. This vacuum sucks that charges back in when available.
So Tesla was right about the expanding baloon analogy. Pull out charges and let it snap back via vacuum and it will create an oscillation of that baloon. A baloon might not be the right analogy though. Lets say the baloon is thicker and in the original state it is say 10 cm across. Suck out some air and the thick baloon resists this extraction and causes a vacuum. Release the orifice that you used to suck the air out and it will suck in air to bring it back to it's rested state. But as we all know it will overshoot and draw in a slight more air to become pressurized and it will then release that air back out and over shoot again sucking in less and less air as the cycles continue. The maximum solution is to periodically suck on the baloon every in and out motion for a complete cycle or to tap the swing every in and out cycle. This is a rather bad analogy but you get the Idea I hope.
One experiment that I think related fundamentally to this is the crystal battery. We are using matter and it's different forms to create a flow of current through a highly crystalline form of matter. This crystalline form of matter creates a diode of sorts when first formed. We use two metals of dissimular makeup that have a difference of potential. This biases the crystalline diode on and allows a current of one way to form through the battery. As you draw charges from one material to the other each plate becomes balanced and the flow eventually stops but given enough time for the matter to reguage back to it's normal and the flow will continue. This has been experimentally verified on this forum.
