0 Members and 245 Guests are viewing this topic.
jbignes5
So you say that the ground has no current or even capable of currents?
"In an electrical system, a ground loop usually refers to a current, almost always unwanted, in a conductor connecting two points that are supposed to be at the same potential, often ground, but are actually at different potentials. Ground loops created by improperly designed or improperly installed equipment are a major cause of noise and interference in audio and video systems. They can also create an electric shock hazard, since ostensibly "grounded" parts of the equipment, which are often accessible to users, are not at ground potential."
http://en.wikipedia.org/wiki/Ground_loop_(electricity)
So this explaination is just a dream? This is a well know acceptable explaination of ground loops. I'm not dreaming. If the ground is capable of carrying a current then it is capable of producing currents. What initiates a ground loop is two points of a conductor that have a potential difference. Weather that conductor is the earth ground or a ground plane or even a conductor it is all related to this process. Why are you ignoring these facts?
So the experiments that I showed have nothing to do with this process?? I showed each piece and the experimental proof how it is accomplished.
Anyways it doesn't matter if you believe me or your eyes, this is the avenue I am going down now. When I get the experimental proof I will show all.. Hopefully I'll have a decent video camera by then.
Hoppy
Quote from: jbignes5 on February 01, 2013, 05:19:33 PM
Its well known that natural telluric ground currents are produced primarily through geomagnetics but I've never heard of these being used to power banks of 1KW lamps! I wish you the best of luck in your attempts to conjure up these telluric currents to run your electrical loads.
elementSix
RESONANCE IN RESONANCE
Using a High Frequency system that has a certain waveform and is self adjusting.  Can you use a HF pulse  into a Large Primary Coil that is Tuned to resonante at the  high frequency pulses?  The secondary coil could be tuned to a certain frequency , like the earths natural resoance, which is around 7.5 to 7.83 Hz.  The seconadry Coil could also be tuned to the resonant frequency of the primary or  it can be tuned to the resonant frequency of the lower energy it recieves from primary induction.  Are you following me.  There are a couple ways of producing this excess energy, that I'm trying to convey to you guys..  By having a large primary, with few turns over the secondary, and having the HF pulses being shot thru the air and into the secondary coil that is either tuned to the primary and or the Earth.  But when the inuction energy from the primary enters the secondary, it is at a much lower frequency.  So the secondary has to be tuned to that frequency.  So if you adjust or set up the Primary coil and capacitor to the right range of HF, so as to have the induction energy produced in the 2nd coil the same frequency it is tuned to, which would be the Earths natural frequency..  Sorry if I'm not to precise with the way I am presenting this.  By this simple arrangment, If this is possible in any of the ways I have said, please put your 2 cents in.  I am still learning about Resonance, So if something I have said is not possible, let me know.  Thanks for your added input.
elementSix
You have to remember that there are a whole building of Illuminati Government Trolls that are paid to work the internet and especially these forums.  So don't be discouraged by non-believers or bashers, cause most of them are paid to through you off and lead you down the wrong path.  They use many screen names and even support themselves with those screen names. But you can also learn a lot from our fellow members, So just be nice and open minded and test your ideas, cause unless you test them you may never know. Remember that Small Minds Live in Small Worlds.  Good Luck
jbignes5
Quote from: Hoppy on February 01, 2013, 05:44:57 PM
Telluric currents are a natural effect not the effect that any on these examples use. If you agree that telluric currents exist then there must be a way to artificially create them and utilize them. But like I already said the telluric currents are but one form. Ground loops are not telluric currents. It is a current that is set up via two grounds and applying a potential to one of them. But this can be used in such a way that you loop the current into the device and utilize the current to cause a heavy magnetic field which you can induce another current from then disconnect you system from the ground and let it rebalance.
Listen I don't wish to have any more conversation with you about this. Simply because you are another of the people here that seem to explain this process like it is magic. Conjuring is not what I do. Utilizing a natural form of energy ie. motion of charges is not conjuration and we do this every day. What is a water fall?? Don't we harness them? Is that a friken conjuration???
Please if you are not here to research and explore these effects then stop wasting our time ok?
What I don't understand is that why are you people here? What is your purpose for being on a free energy research forum if all you do is make fun of honest people.
I'm curious.. Got to have stephan do another ip check...
So now Hoppy goes on the same list of word twisting nay sayers like the great deciever Verpies. Verpies is wasabi and decieved us all by creating another personna on this forum to belittle and decieve us. I wouldn't believe anything Verpies says at all. He has shown his intent and his ability to lie to us all.
