a.king21
Quote from: elementSix on February 02, 2013, 12:32:00 AM
Thanks A.King21,  That was a great video.  How would that pulse be created by a circuit.?  Isn't that what TK's doing?  He did site Bedini in his Patent.. He could be  Using that impulse waveform, but with Solid state instead of monopole??
AC
jbignes5
I just wanted to clarify a few points about the character of currents. There are two different components to all currents. One is voltage and the other is amperage. One leads to the other in a wire. Voltage is the genesis to current. And as has been shown you can have a high voltage with very little current. This fact means that the voltage goes unhindered because there is little real amperage to get lost in this character of that type of current. A resistance to this kind of current poses no real hinderance and flows readily. Most resistors will not heat up and will seem to be not there at all. This is why Tesla designed very high voltage lines to transfer the power from his source to the end consumer's transformer. It allowed for a very low loss when in transportation over very long cables. The less amperage you have in the current the less of a reaction the current will pose to the resistance. But in that example there is a higher electric field effect from the transmission wires. If the power companies had applied the static shielding that Tesla devised via patent they would have reduced this field effect and would have very little loss at all. But of course that would have costed more in initial investments.
Has anyone thought about why they got rid of the power station at niagra? It was free and after many years paid for the equipment that was installed there. They could not justify raising the prices we pay for electric so they devised ways to get more from a system by removing the part that gave free energy to all. It makes no sense at all except to increase the cost of power that could free man from the chains that binded him.
The concepts that Tesla was working on like transfer of energy without wires woulkd have made it very impossible for power companies to justify charging for something that was paid in full many years ago.
His wireless concepts were very simple to understand. If we excite the metal ball we live on it would develop a field all around the ball and would only have a very short distance to the end user reducing the loss even further. The rubber ball that Tesla envisioned in his analogy would move equally at any point around that ball and each station would only go to strengthen that field going in and out around that ball.
His experiments with capacities above that surface prove beyond a shadow of doubt that one could tap that field with accuracy since in relation to the surface you could easily calculate the amount of power you could get due to the heigth above that surface.
Eventually Tesla found out that one didn't need the earth to do this. Only a capacity is what was needed. Since he related the earth to have a capacity and for the matter of fact any conductor has a capacity. This capacity is mass based and the resting capacity is based on the distance above the earth in relation to the earth if the earth is used. A capacity could be concidered as a spring bound by the matter. Learning how to utilize that capacity can and will free you from the chains that bind us all and this scares a great many that make a living from the current process. Hence the deception of a great many book thumpers here.
TK is only reporting, not to us but the world of what he did. Why? because the ones in power are doing nothing to bring these facts out. Those videos were not made for us they were only a record of what he had learned. The only thing TK is guilty of is taking the experiments and expanding on them like TESLA said we were to do. He applied the techniques of Tesla and they worked. Plain and simple.
There is a simple example I would like to share with you.
In the training process of an elephant they use a heavy chain when they are young to bind them to a post and keep the baby elephant bound to a certain range. As they fight against that chain they learn that they are limited to that range. As they get older and much stronger the trainers change the chain to a flimsy rope but yet the now adult elephant still stays in the range of that flimsy rope. It never tries to go beyond because it knows it to be futile.
This is where we are today. This is how most are controlled in this field. They are taught to not ask questions that go beyond the scope of what they are taught. They think it is futile. They think within the box made for them. When they step out of line they are ridiculed and called all kinds of names, they are shamed into submission. And if that doesn't work then they are taken out and shot behind the barn.
Not one person on the other side of this example that TK shows us has ever built the device in the proper configuration. Why? Because they could never build it with what they are taught because they know little of the teachings of Tesla. Only what the system teaches them. They will never build a working device because their thinking is trapped in that box. When some of us try to re-educate the ones interested they quickly step in and throw everything they can to discredit the re-educators. They throw all kinds of math and book taught theories at us expecting us to ignor whats in front of our eyes.
Most of these people still believe in the electron. Well to be honest that is something that never will be seen but yet they believe with all that they are that it still exists because that is what they are taught as young explorers of this field. It's like the chain and rope example. Not true but yet held as truth because it is all that they know. The belief in the electron is most unscientific. It goes against everything they are taught yet they still believe.
Now I see that most colleges have corporate sponsorship???? WTF... Injstead of doing this through peer manipulation they are now getting directly involved with tightning the chain. This is most unacceptable in my opinion. When are we gonna say enough is enough? When are we gonna listen to the ones who show us it is possible?
TK did what he did because he didn't have this teaching telling him it was impossible. He learned from the one source that also self taught himself by example. Tesla.
This is not hero worship in fact the ones hero worshiping is Verpies and the others who admire Einstien and the rest who chained them into thinking that nothing is for free when in fact there are processes out there that do not run with wires and sources of current. Natures does not have a bill for you to pay. The price for a water fall has already been payed and is free for the taking. The waterfall would still run just as well without thier input and does so till this moment in time. We just need to recconize the systems in play and learn to intercept them and harness that power for our own uses.
I'm sorry for the long drawn out post but I think we have to start looking at what is wrong in this picture and I hope this is a better description of the problems we face in the free energy field..
segar
hi, FreeEnergyInfo
actually to post its simple, but must have proof and reason ,but when see the your circuits ,its not free energy and also its largest loses power will happens, the reason is input DC and change to AC back again, this is the big loses in the circuits shows.
all is direct switching element , have to consider its not correct solution to do experiments.
thank you
jbignes5
Quote from: a.king21 on February 01, 2013, 10:35:19 PM
Tesla's impulse technology:
http://www.4shared.com/video/gGAKnsmi/Energy_From_The_Vacuum_Part_07.html
That is exactly what I have been trying to relate. To the letter. Although the method is very different then TK's it is the same non the less.
In TK's method the ground is the source of charges. In bedini's method it uses batteries to strengthen or condense the energy. Thats the difference between silicon vs. spark gap. Silicon=weaker, spark gap is much stronger. Batteries use ions and TK's method uses charges in the ground matter.
In the video you can see Bedini still stumbling with the explanation he is presenting. This is because he still hasn't gotten the total picture but he is very close now. Even Tesla didn't have the total picture and relates that we the future generations were left to devise the total picture. If we can get past all the name calling and degrading comments we just might be able to figure this out. It is gonna take a new understanding of nature and the nature of objects in our environment to fully figure this thing out. Fields play heavily in this new view. Both the electric and subsiquent magnetic fields need to be explored fully before this understanding can mature.
Resonance also has a deeper meaning as well. Not only do we need to work with resonance in electric ways we must also work with resosnace in mass and this is key. Division of that mass determines the outcome as well which I suspect has to do with surface area of an exposed mass to the field.
Lets look at this reference: http://intuitor.com/resonance/circuits.html
Ignore everything but this statement:
" Note in figure 7 that we have put a resistor back in the circuit. If there is no resistor in the circuit the current's amplitude will increase until the circuit burns up. Increasing resistance tends to decrease the maximum size of the current's amplitude but it does not change the resonant frequency. "
As I have stated before higher voltage low currents do not react the same way as lower voltage higher currents do with resistances. In fact the higher voltages act like the resistance is nil or not even there. And this is the key! Now can we figure a way to extract the amplitude at a precise level and dump the excess before the ciruit burns up and power a load by converting the very high voltage to low voltage high current in our load?
Jon_sparky
Outstanding post!  too bad about the elephants  ;)
Quote from: jbignes5 on February 02, 2013, 10:45:21 AM
Has anyone thought about why they got rid of the power station at niagra? It was free and after many years paid for the equipment that was installed there." ...
