0 Members and 28 Guests are viewing this topic.
Hoppy
Quote from: elementSix on February 04, 2013, 03:45:32 PM
It is interesting that in the GB video, the camera man pans to the welder in the garage.  I believe that it in the 2Kw version also, but I might be mistaken.  He could be using something out of that welder for HV or HF application.
Maybe even using a welding transformer as a source of low voltage / high current carried by the heavy duty thick wires seen in the 'green box' video. Then converted to HV in the device?? At least no risk of electrocution that way having a wire running up the guys sleeve and down his back and wires all over the shop.
garrypm
Guys,
Sorry, I think you have all taken my post about the 3 phase out of context.
I was simply pointing out that in looking for a way to "cheat" the power meter, I came across that statement about the 2 phase welder.
Sorry if anyone got the wrong idea.
Garry
Farmhand
Quote from: elementSix on February 03, 2013, 10:14:47 PM
http://www.youtube.com/watch?v=UsS0BeVeIwM    Karl Palsness AEPC 2009
These 10 videos are mainly on Tesla Hairpin circuit, but they have some good remakes of Tesla HF transformer that is specially made and when powered up it draws large amounts of Ambient Energy to it.  He says that in the dark you can see the wire coil he holds up in the Air, light up a bit and you can see the energy going toward the HF Coil. Watch it and lets try to make this special HF coil..
Which video clip is that in ? I don't have time to watch them all. But going by the description it sounds normal.
I can fire up my Tesla coil with a toroid terminal and when I hold a wire near it or a fluro tube the arcs tend to form from the pointy end of the held wire
or tube and go towards the coils terminal. This is caused by the potential difference and the fact that the charges will not leak from the terminal as easily as from the
pointy wire. Similar to how leaders form from the ground up to initiate lightning. Bottom line is the potential is provided by the transformer and the input from us,
the effect is the result of that.
These are low power low frequency discharges so that I could look closely directly at the arcs.
And the sparking electrode is ground connected or just connected to a metal mass. The moment the bright white sparks are seen is when a conductive path is formed by the
leaders from the ground up. Just as with lightning.
http://www.youtube.com/watch?v=zpoqUo0Wvoo
http://www.youtube.com/watch?v=6ojAlZrUZxE
This one is a 12 volt transformer and the neon is held in my hand the arcs go from the neon to the terminal.
http://www.youtube.com/watch?v=1uaZubgmnL8
If you suppress the leaks from the Tesla coil terminal and supply a pointed object nearby the pointed object will leak towards the coil.
I can demonstrate this with my larger higher powered transformer but it will take some time to set it up.
It pays to do lots of experiments, make lots of observations and become familiar with resonance either by technical means or by "feel" or a combination of both.
I try not to get to technical, because I like to do things by feel. Therefore my explanations will not be overly technical.
Cheers
elementSix
It's a special power supply that has a few options on what your needs are.  They have pretty high current with mid level voltage outputs.  They are usually pulsed systems that have a very fast pulse rate.  The diodes are able to pulse very high currents ranging from like 20 Amps all the way up to hundreds of amps.  The specail thing about them is what we are trying to accomplish.  Using a special pattern of timed interval pulses.   The only way to get the devices we are working on to work right, besides knowing  what to do, is a pulse that can turn on and cut off in a very very short period.  Other than that I don't know much about Laser Drive power supplys or Laser diode drive circuits.  It is interesting none the less.
In TK's first patent, he changes the frequency of the positive and also used car ignition points on the positive.  The negative went thru a frequency filter, I am guessing to put the phase off before it went to the coil.  If you watch the Transparent Box video with the Red Coil setup, you can hear when he starts the device for the first few mins., it is out of phase and you hear the coils screaming.
What would happen if you pulsed the positive and put the negative out of phase??  Any takers on that??
FARMHAND, Its the 7th one....
Zeitmaschine
Since I still can't get any useful resonance while experimenting with RU-2386207, I decided to do more reading (instead of watching shaky odd things on YouTube):
The parametric transformer, by Eyup Salih Tez, 1977
Hence does the term »to produce output power« mean what I think it means? So then what could be the problem here?
Wave diagram below: Analysis of the loud humming noise in the TK 2004 Video superimposed with a 50Hz sine wave. The mark »0.100« denotes 1/10 second. This means the humming noise correlates with 50Hz and 100Hz. This is an interesting coincidence given the statement in the doctoral thesis »the inductance of the secondary winding is varied at twice this frequency«.
So I have to keep on reading ... :)
