0 Members and 106 Guests are viewing this topic.
Osiakosia
Quote from: Zeitmaschine on February 06, 2013, 08:50:22 AM
Supplement: Could it be that the yoke device works only with that special Russian type of ferrite (ОС-90.38ПЦ12) because it is low quality and therefore it is easier to magnetically saturate it? :)
Like T1000 said in one of him yoke device video , he take the OC-90 core accidentally by one simple reason -- it was the biggest
ferrite core that he could find . After examine russian OC ( Отклоняющая Система  ___ Deflection system ) cores I find thats is true
OC 90.38ПЦ12 deflection system hade one of bigest ferrite made in USSR - OC-5 ( please check in attachment ) .
By the russian technical books( page 679 in attachment ) then big ferrite cores are exposed to HF magnetics field ,  the cavity resonance take place in this
cores . And it manifest at frequencies around 1mhz . The others cores may work at another frequencies , but T1000 could not
work with frequencies above 2 Mhz couse Wellman pc based functional generator PCGU1000, that he hade use , work only till 2Mhz . So he was lucky- the
generator  frequency range match the ferrite core rezonance frequency .
http://www.vellemanusa.com/products/view/?id=523616
andrea76
at the end of the TK patent ,in the "documents considered to be relevant" ,reference is made to the device of Bedini.its devices nothinng to do to the Tesla Transformer.just Bifilar coils. TT is only smoke and mirrors.like the grounding wire( it is just to prevent the high voltage static charge).
zcsaba77
Quote from: Osiakosia on February 06, 2013, 11:30:30 AM
Only Antanas personaly can answer this question.
Hi
Mr Antanas english skill, may be is too weak, because I so many posted/asked him and about these devices, but no answer, and my russian language skill is weak too (maybe little bit understand, but read and write is nothing, only in 5. class I studied)
thanks for links, is usefull information for me
rgrds zcsaba77
NickZ
  In the patent it's stated that a battery can also be used for the input source, and also that the secondary coil output is sent back to help recharge the same input source battery.
  That would mean that solar panels can also be used to maintain the input batteries constantly charged up, and at a relatively steady levels.
  I'm interested in having an "off grid" type of system, one that does not rely on the use of expensive test equipment to function properly.
   Thanks to all for the info
   NickZ
