0 Members and 70 Guests are viewing this topic.
Grumage
Quote from: verpies on February 09, 2013, 05:43:41 PM
That is unusual - I will think about it some more.
Of course voltage alone is not power nor energy.  Most likely you'll need to measure current & voltage simultaneously by your scope to resolve this.
Thank you, What I am trying to say is that there is something curios about the relationship of Ferrite and HF, you can hear it hissing. I wonder whether there is an interaction with the binding material?
Grumage
Quote from: elementSix on February 09, 2013, 05:17:22 PM
Thanks a lot for your Input, GRUMAGE..  I verified your findings with the Strange Russian Transformer...  I used copper ribbon and made a tube with it, but I left a small gap, long ways.  So that the tube wasn't fully a tube.  It sings like a MoFo.  Around1300Khz, It got so loud that it hurt my ears.  I used a 5 volt output from my Function Gen. and hooked up a long wire through the copper tube that was inside of the ferrit rings and hooked the wire to a LED.  It only lite up in the KHz range.  The function gen. can only lite the LED up just a little bit when I hook it up directly to the GEneerator.  I am going to try your version of the Peizoelectric transformer tonight.  But I appreciate your input on this subject and your videos.
Thank you for your appreciation. But you should use a filament bulb for your tests because the output is AC, your LED will only conduct on every half cycle. You would also get a better result if you could drive the primary with a Sine wave, I got little to no noise from my core.
But keep at it, it's the only way we are going to make any headway towards the common goal!!
SchubertReijiMaigo
Quote from: forest on February 09, 2013, 03:40:10 PM
"A voltage is not energy...
You have a resonant rise, try to load that, resonance get killed and loading the input like any Xformer. (conventional theory)"
and what is the correct question ....hmm? Having the good question is like having half the answer
It was that...
QuoteFurther tinkering today saw with a 2.2 mFD cap across the open link between primary and secondary Ferrite rings. Still with 1 to 1 to 1 ratio. With 10 volts P/P in we saw 80 volts P/P at output. This only occured at around 30 kHZ I am assuming a resonant responce?
Then I exposed both theories:
The conventional when you have Under-Unity.
The Hector Perez OU theory.
If he have equipment he can now play.
gyulasun
Hi Folks,
I think that in Grumage's toroidal core(s) when they get the drive at 30 kHz, a mechanical resonance may develop in the core(s) and this may explain the extra induction?
Here is a data sheet for a Ferroxube toroid core and just read the 'Remark' under Fig. 4,  PDF file Page 3:
http://www.ferroxcube.com/prod/assets/3r1.pdf
and from the mechanical sizes of the core(s) the resonant frequency can be calculated.
I wonder if the sizes match to the 30 kHz frequency?
rgds, Gyula
cheappower2012
Hoppy
I do have an agenda but it is not to
fool anybody ,misdirect anyone or get attention.
