0 Members and 220 Guests are viewing this topic.
SchubertReijiMaigo
@ Forest, sorry I still don't get it here.  ;D
Maybe "What is the difference between voltage and energy ?"
Or simply: "Where is your load in your circuit ?"
If I ask like this you can find a part of the answer...
leo48
The tension is not energy but is the parameter that decides where the energy flows
having two parts one has a high voltage and low energy and the other low voltage and a lot of energy, brought into contact with the energy will flow from that to higher voltage than that in the lowest
;D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
verpies
Quote from: leo48 on February 10, 2013, 06:34:17 AM
What about electric current?  Current is composed of moving charges in vacuum, plasma, gases, liquids and solids.
Doesn't voltage influence their motion?
cheappower2012
It can never be said that TK's device is 100% real however,there are things
that can not be easly explained.In the 2004 video,when the plug from the inverter is removed
for a while the lights continue to light going out after a while followed by a strange noise.
I am very good at creating illusions,why would he build in this effect,when the inverter was removed the lights should have gone out
very quickly with no strange noise.In my exploring hes setup I discovered that the clampmeter he uses in the green box video
has a strange effect in that it
indicates ground current when there is no ground current,the reason he can't read the ac voltage is for the same reason,pulses
induced into the ac that mix with it.
It turns out doing more research  the meter I have is made by the same company
that made TK's and is a lesser model m266 instead of m266c so the circuity is about the same.
Since in the green box video they couldn't measure the ac voltages there are pulses in the ac ,these cause false readings,
a constantly changing ac voltage the same as I got.If this changing ac voltage measurement is present
then the meter will read a false ground current.Tk attempts to hide the device by saying its a tesla invention
,in the 2004 video there is no guy with a ground cable running up hes sleeve,the guts in the 2004 video are in the green box video.
In the transparent box video,there is a strange noise,it turns out to be 400hz,when the device starts, its loud,after awhile it goes low,when a bank of lights are added at first the noise is very laud
then it goes down.Why add this strange noise normal con men don't do this,this noise has something to do with the operation of the device.
One problem I have and that has to do with lights used,1,000 watts is very high for a house hold lamp,I would guess there 100 watts,so the total would be 500 watts,however I live in the US we use 110 ac.It maybe that the bulb is 1,000 watts there should be some members here that live in that area and would know.
There is a problem in that its hard to believe that Tk could discover an effect missed by the physics community,but I think
because he doesn't know not to try something he did
and discovered this effect this led to the device.In the US ,SM also discovered this effect,this led to the tpu
after a period of years of experimenting.This is speculating,I believe that there exists an unknown energy source very dense,missed by the physics community
devices like the TK device and the tpu are able to take this energy source and convert it into electrical energy,because the energy source is very dense
great power can be extracted from a small space.These devices are energy converters,not free energy devices.
