0 Members and 87 Guests are viewing this topic.
Grumage
Quote from: verpies on February 10, 2013, 04:11:28 AM
Sound is caused by magnetostriction or core slapping due to Ampere forces.
Graham Gunderson has a patent for an energy generator using magnetoacoustic phenomenon.
Anyway, your 1:1 transformer is symmetrical - do you still get loaded voltage increase if you connect it in reverse? sec<->pri
Humble pie time!! And an apology. Measurement errror, my 40 W amp module would not allow me to connect the ground lead from my scope probe, it short circuited the output. Like a fool I left it open.
Having removed the earth from the 13 A plug of the scope, this enabled me to connect both sides of scope probes to the input and guess what? input matches output, MAGIC!!!
So once again measurement error can play a part in fooling us all, sorry guys, I will try to do better. :-[
verpies
Good scientific attitude. Many people would be afraid to admit a measurement error.
However the worst errors are conceptual.
Grumage
Quote from: Grumage on February 10, 2013, 09:40:30 AM
I have spent the best part of this afternoon (it's raining anyway!!) going over my results, to find all tests done on my pseudo parrametric transformer to be DUD. So I decided to recheck the tests done with the special russian transformer, these are still perplexing.
Results.
16 V P/P in (earth gounded probe) @ 20Khz
15.9 V P/P out (earth grounded probe) Into 20 W 12 V Halogen bulb.
DC input current, inc amplifier quiescent @70mA, Was 490mA
Output current determined by voltdrop across 1.09 ohm resistor in series with load.  3 V P/P (scope measured).    So 1.5 div by 0.7071 div by 1.09 = 1.946 A
Am I right? I am beginning to doubt myself!!
My reasons for persuing this avenue is because I feel it is the heart of the TK device. And that of SR193.
Hoppy
Quote from: cheappower2012 on February 10, 2013, 07:25:09 AM
It can never be said that TK's device is 100% real however,there are things
that can not be easly explained.In the 2004 video,when the plug from the inverter is removed
for a while the lights continue to light going out after a while followed by a strange noise.
I am very good at creating illusions,why would he build in this effect,when the inverter was removed the lights should have gone out
very quickly with no strange noise.In my exploring hes setup I discovered that the clampmeter he uses in the green box video
has a strange effect in that it
indicates ground current when there is no ground current,the reason he can't read the ac voltage is for the same reason,pulses
induced into the ac that mix with it.
It turns out doing more research  the meter I have is made by the same company
that made TK's and is a lesser model m266 instead of m266c so the circuity is about the same.
Since in the green box video they couldn't measure the ac voltages there are pulses in the ac ,these cause false readings,
a constantly changing ac voltage the same as I got.If this changing ac voltage measurement is present
then the meter will read a false ground current.Tk attempts to hide the device by saying its a tesla invention
,in the 2004 video there is no guy with a ground cable running up hes sleeve,the guts in the 2004 video are in the green box video.
In the transparent box video,there is a strange noise,it turns out to be 400hz,when the device starts, its loud,after awhile it goes low,when a bank of lights are added at first the noise is very laud
then it goes down.Why add this strange noise normal con men don't do this,this noise has something to do with the operation of the device.
One problem I have and that has to do with lights used,1,000 watts is very high for a house hold lamp,I would guess there 100 watts,so the total would be 500 watts,however I live in the US we use 110 ac.It maybe that the bulb is 1,000 watts there should be some members here that live in that area and would know.
There is a problem in that its hard to believe that Tk could discover an effect missed by the physics community,but I think
because he doesn't know not to try something he did
and discovered this effect this led to the device.In the US ,SM also discovered this effect,this led to the tpu
after a period of years of experimenting.This is speculating,I believe that there exists an unknown energy source very dense,missed by the physics community
devices like the TK device and the tpu are able to take this energy source and convert it into electrical energy,because the energy source is very dense
great power can be extracted from a small space.These devices are energy converters,not free energy devices.
Thanks for your honest assessment of the TK devices. As you comment the wire up the guys sleeve was not an earth wire, it was carrying the power to the device IMO.
I most certainly agree with you that TK's devices convert energy and do not produce free energy. However, the challenge is to prove beyond reasonable doubt where the source energy comes from. There are clearly differing opinions / guesses on this and this is how the situation will remain until TK himself decides to come clean on the modus-operandi of his various devices to a level of detail to allow multiple replications to be built. Its not a case of trusting or not trusting anyone's explanation, as the truth that his devices are in some way special and important to humanity can only come from open sourcing, leading to multiple replication. In the meantime, we can all continue having fun guessing and building this and that idea.
a.king21
Why don't you b.... skeptics just read and analyse and comment on his patent applications instead of going round in circles. The patents tell you how the device works.
