0 Members and 198 Guests are viewing this topic.
jbignes5
 So you are finally coming around to the fact that this is only a conversion device? I said that like days ago. Yes they are converters and yes, science in it's infinite wisdom, decided this source was only a toy. A novelty that couldn't power anything. Well they were wrong were they not?
The source is static but is the reason for all movement in the universe. IT is the initiator of all current and flows that current.
Tesla found the perfect analogy of the infinite energy engine in the submerged container. As long as he could dissipate the in coming stream this engine could pump indefinitely as the stream dissipated. The ground represents a mass that is charge deficient. Plenty of mass but not enough charges to keep it balanced. Radiative events keep the matter in a depleted state. Of course this changes the further you go inside of the earth. Inside there is charges in abundance(heat). This is due to the massive body of the earth and due to static rules. Since there is no inside surface per say, The charges bunch together and cycle in and out of the core. There must be a crystal in the core most likely a ferric diamond type.
This ground is in a vacuum state. We can use the ground to drain away the energy that gets attracted through the coils. Remember this is an exciting field. And ground sucks up this energy like a sponge.
I'll chat more about thins later. I'm on my iPad ATM.
cheappower2012
a.king21
You still hanging around,TK made a fool out of you and your crew.
You still don't understand the level of deception TK operates under
he would never put down in paper,how to build hes device.
Some of your beliefs are silly,related to how it works.
You refuse to answer some simply questions,make of heater,did you
supply the heater,does the heater have a fan.
I believe that you said that you disconnected the ground and it still worked.
Its obvious your crew can't figure out how to build it,because the power shown
is very great the first thought is its a fraud.TK doesn't look like Einstein
more like a cheap Santa Clause working in a junk shop,pushes credibility
to the breaking point.This is why some members here think TK is a fraud.
idzaza
Quote from: cheappower2012 on February 10, 2013, 05:09:48 PM
a.king21
It is not only a.king21 who saw working device, there are many others who saw many different types of devices built by TK and even helped him in the process of making them. My guess is that he and people around him have been warned to do the way he does and no more. There is a topic about TK in one of well known forum website in Georgia, there is no any useful info in that topic just some users claiming that they have seen the devices built in the 31st factory back in 2000, but projects have been stopped, we do not know reasons they say. What I learnt so far the kind of secret is a HV HF in the primary coil. What is written in the patent seems to me to be correct but there is no specific explanation like at what volt, at what frequency the basic device's primary coil resonates. There are people saying they have seen it working, and could not detect any external source, the devices have been demonstrated at many places in Georgia at different levels and not only, however nothing happened. As far as I could find out the devices in Turkey were not fake. My guess is that he is in a difficult position due to the fact he is surrounded by idiots dreaming, may be on purpose also he is getting old for all this. May be it is just me see them as idiots.
a.king21
a.king21
You are writing bollox.
jbignes5
Quote from: leo48 on February 10, 2013, 06:34:17 AM
The tension is not energy but is the parameter that decides where the energy flows
having two parts one has a high voltage and low energy and the other low voltage and a lot of energy, brought into contact with the energy will flow from that to higher voltage than that in the lowest
;D
Leo48
Very close. You have a fundamental grasp. What you need to relate now is the rules for static fields and charged objects. The object is balanced when no apparent difference  can be measured But apply a potential difference between two different spots on that body and it will pull charges out of balance. Through induction  by the segments of that body, one can get a diode type action with an increase in voltage from one end to the other. The thought is that matter creates an inertia. This inertia can be used to an advantage. When tesla figured out that static like electricity from his special transformer behaved similar but was still convertible because matter is associated with the field, he fine tuned it to produce huge movements in the matter. Vibrate the matter with the field in the harmonic of the matters frequency. Copper becomes a super current pump especially when it has higher masses.
Remember Tesla when he was talking about the proper resonant frequency for the earth in his world transmission system. That frequency is the tune of the earth that he was trying to oscillate. Although in his concept the earth was the transmitter element and the raised dome was the capacitance to push the earth or transmitter element with. In TK's system he uses the earth to suck the high frequency radiation into the center of the device (Backyard video) and intercept the frequency via a bifilar coil wrapped inside of the radiator element. I'm now thinking the output is very DC or highly pulsed DC. This highly pulsed DC must be converted to AC (isolation transformer) then converted to DC to strip it of frequency then back to the input. This process cleans up the power and isolates it from the load and drive Inverter. I know this sounds lossy but if you get it for free who cares if it is lossy, in other words does it do the job, yes. Is it efficient? No but it is free.
The action of this field when tuned to the coppers frequency, after all resonant calculations should give us the desired ping field frequency of this field  We should be testing the fields effects on copper. I had Itsu do that and there was pretty interesting stuff going on. Of course he was trying to energize aluminum capacitors I bet this works with copper better if there is sufficient mass to the copper.
Thinking about the one way diode action of a bifilar coil one could see how a vibrating field would stimulate a lot of current from that coil in a DC like manner.
