Zeitmaschine
Quote from: a.king21 on February 10, 2013, 03:37:22 PM
Why don't you b.... skeptics just read and analyse and comment on his patent applications instead of going round in circles. The patents tell you how the device works.
Then surely you can give a hint which coil in the patent is which coil in the 2004 video. It can't be the big coil because in the Green Box video TK itself says the resonator is inside (the box). So the big coil with orange cable is out of the question. Hence where can I see the coils in the 2004 video as depicted in the patent?
Quote from: verpies on February 10, 2013, 10:31:15 AM
Good scientific attitude. Many people would be afraid to admit a measurement error.
However the worst errors are conceptual.
But I think the TK device works just because of a conceptual error. Of course it has to be the right conceptual error.
OK now, in search of excess energy I have wound a yoke device myself (ferrite core of a flyback). But instead of excess energy I've got a Perpetual Motion Holder made of ferrite. What could this mean?
One bifilar coil is connected to a Joule Thief circuit, the other to an incandescent bulb. The bulb glows slightly, the ferrite makes strange noises. After disconnecting the power from the Joule Thief the half cores stick together till I shake them apart. So this seems to be the Leedskalnin effect. Now what to do with it? ???
Supplement: The Perpetual Motion Holder holds only when a load is connected during switch-off, seems there has to be current through both coils.
verpies
Zeitmaschine
Quote from: verpies on February 11, 2013, 09:40:51 AM
How is that different from ferromagnetic remanence?
Once separated the magnetic force is completely gone (till next connection).
jbignes5
 I just started watching the turkey investors demo and it really dawned on me what the differences are between the 2004 backyard video and the 2005 Turkey investors video. One is a single phase Square wave output, backyard 2004. The other is a 3 phase unit 2005 Turkey investor unit.
The back yard video shows an inward electric field and the 2005 video shows an outward 3 phase generator. In both instances it used a heavy copper radiator that is segmented, loops. This allows the field to have spin and acceleration from one end of the heavy coil to the other. It is most likely discharging to ground through the heavy coil. As Tesla found out things change when ones does this to copper or other great conductor. The thicker the material the better it holds up under the pressure of the voltage discharge.
I mentioned before about how matter can filter this filed and give the field pressure, polarization, diode like character and more interestingly texture to the field. Like gearing works these fields can and will work the same way. But one also needs to remember that more importantly it acts like a super fluid.
I also believe very strongly that TK'S uses iron filings in the copper tubes to make sure that only the electric field is the only field at play in the coils around the main coil in the 2005 video. Any other fields would be present within each coil around the central mass and center it perfectly inside each phase coil. Maybe an interaction of the two fields in the proper place cause an amplifying effect within each load/phase coil.
even though the first video in 2004 had only one phase it still makes sense when you look at both the 2004 and 2005 videos.
Hmm.. Seemed to have rambled a bit there. Sorry.
