0 Members and 1887 Guests are viewing this topic.
andrea76
Quote from: Choose username on September 08, 2011, 10:34:42 AM
It`s interesting:
translate from 22min 00sec:
(guests=GS, Kapa=TK)
TK22.00: when we will repair the electronic starter, the spark will not be here. Also not to be this noise,
listen- it is almost unheard now, because device is entering normal mode. But small noise you can hear, if you get closer.
GS22.20: I hear small noise from the rear of the box.
TK22.25: Because here is a very big load.
(At 22.30 unexpectedly the spark began to clicked very often)
TK22.31: it starts to regulate itself.
GS22.33: there is something wrong!!
TK22.34: no no, nothing wrong!
GS22.35: look - it is a smoke from the bottom!
TK22.44: let's we give it a rest
GS22.45: overheated...
TK23.01: i will check it all
GS23.12: maybe it is so, because your fan was off..
TK23.12: the fan should not work until the temperature will not increase (thermostat)
another interesting moments:
TK05.18: ..and there, from the third coil we take so many elecricity, how we need.
Really i don't want to say this, but i will say that the main effect is there.
(Tariel draws attention to the fact that the coils should be located so, and not the other way,
because the interaction of electromagnetic fields is needed.)
At the 10.10 Tariel suggests that if he put the battery other way round - device must stopped.
But it did not happen  ;D
From the 11.46 TK tells the guests about Tesla's electrocar, and say that probably such box
was used by Tesla installed under the seat.
One of the guests ask TK "What happens if right now we tear the grounding?"
TK19.29: once it was so, my assistant did it. Only the electromagnet was burned, and
nothing more.
(aha! electomagnet is used inside! but for what? hmm..)
At the 19.45 talk about the kapagen's stability with the working load. It can be low
and high. But at the traditional power plant, disappearance of the load is a accident situation.
Inside the box we can see many printed circuit boards. Some users at the russian forums
(who repaired old USSR TV) identified vertical unit,HV, etc... This PCB don't look as altered
or as resoldered. For this reason many people assume that this is a usual camouflage.
Something to remember..
andrea76
Quote from: Choose username on January 27, 2011, 11:33:05 AM
0:15 -It is less, than 4 ohms. Good grounding here
0:18 -Now ground is entering device
0:23 -Here are a first coil
0:30 -Second coil..
0:34 -Most important: here are 3 coils total. Tesla had 3 too.
0:36 -This is independent coil. It is located here thus,
         because it must be influenced by an electromagnetic field from the first
         coil.
0:53 -And here, this big black detail is a radiator
0:57 -Count quantity of this lamps. 200 watt each. 3 kWt here.
1:22 -...(?)we have replaced it. Before at us was electronic,
        but it has broken.
1:33 -It will be checked first of all for density of an electromagnetic
        field, and maybe for radiation too. Because first of all we
        have corrected it.
2:09 -Look, you can stand here and touch ground and no problem
2:12 -It is better to hold it in hands
2:17 -Let I will hold it
(Georgian language only)
2:51 -...Heat because right now it provide a lot of amperes
2:59 -But here.. here is not heat
3:03 -We didn't test it for long term. How long it can work in maximal time.
        But it must work a very long time.
        Therefore I have offered to install two such identical devices. If
        the first will stop to produce energy, that second will be
        connected automatically. The consumer shouldn't suffer from it.
End RUS Titles: Let's discuss variants of this scheme realization.
Greenbox was filmed in 2003, this vid and device was before it (?)
andrea76
Quote from: Choose username on January 27, 2011, 05:57:18 PM
On the "Island" (http://www.youtube.com/watch?v=6FhpsbNXLkk) vid nothing to translate... I think this vid proof that device don't exhausts energy from nearest high-voltage lines or something like that.
Below translate for this vid ---> http://www.youtube.com/watch?v=CXwcw1wt0-w
0:19 -What you can tell about your installation for my Bulgarian friends? I already
        start the camera
0:29 -What can I tell? Explain me that you want
0:35 -Camera works
0:39 -What i can tell... 12-15 second.. Here should be manometers, etc.
         Right now we didn't put them. But if they were here, you could see that in
         12-15 seconds here occurs pumping the oil
1:00 -And then it is running in mechanical variant only. Rotation instantly begins,
         because pressure reaches more than 450 Bar
1:13 -Strong pressure!
1:15 -Yes, for this reason it started instantly. Maybe later I will make it
         more accurately, in process of perfection. Now it is very rough work.
         Therefore dimensions will decrease in the future.
1:35 -About principles you can tell something?
1:39 -That I can tell about principles... Nothing))
1:45 -Maybe you can tell it without technical details?
2:02 -(assistant's? voice): You can shooting here what you want, and then let's talk.
         I can help you shooting yourself here too.
2:07 -OK
teofiliuss has told that it was filmed some days ago, Tbilisi city, Georgia. (ex-USSR)
Remaining part of this vid - Bulgarian language, ask those who knows Bulgarian here. I undestand some Bulgarian words. He talking about technical parameters. But this info teofiliuss already gave to us. And I already translated it here:
http://www.overunity.com/index.php?topic=7679.msg272350#msg272350
Once Tariel has told: the most important thing -understand this  hidden principle.Then you can use it to create any device.Without a difference.It can be electric,mechanical,hydraulic,etc
verpies
Quote from: Osiakosia on February 11, 2013, 03:06:56 PM
Three channel amplifier on STK392-40 .
Eagle 6.1.0 files .
Do you have some kind of png or pdf file so that this schematic and board can be viewed without installing Eagle?
What real power can you get out of these amplifiers?
Are they really linear between DC and 3MHz ?
verpies
Quote from: Zeitmaschine on February 11, 2013, 10:05:34 AM
Once separated the magnetic force is completely gone (till next connection).
That's why short AlNiCo magnets are stored with keepers (closing their magnetic circuits).  Without them, they would get demagnetized.
An open magnetic circuit is more demagnetizing to magnets than a closed circuit.  Strange but true.
