0 Members and 220 Guests are viewing this topic.
Zeitmaschine
Quote from: verpies on February 12, 2013, 04:54:34 AM
That's why short AlNiCo magnets are stored with keepers (closing their magnetic circuits).  Without them, they would get demagnetized.
An open magnetic circuit is more demagnetizing to magnets than a closed circuit.  Strange but true.
Another strange thing if true: Magtap: harvesting electricity from a magnet!
gyulasun
jbignes5
Arrggg again with the magnetic. We want to get rid of the magnetic and separate it from the voltage field. Remember a closed circuit for the magnetic effectively creates a magnetic field free zone if you donT saturate the sponge core. It's like purifying the electric field and making it stronger.
Tesla said that this voltage field is expansive and very very strong in a subtle way. This is due to it's super fluidic nature. But it can be condensed and used to induce some heavy currents in matter like copper. I couldn't imagine this process with gold or higher conductors.
Tesla also said he was not using Hertzian waves at all. Hertizan waves are magnetic in nature. Tesla also said magnetic is so wasteful. He also said that you must tune the resonator to the coppers mass. When you change the mass it will change the tune at which it resonates. Other factors like coil construction and methods of coil winding changes things drastically. You might be able to use bifilar coils in such a way to provide all the current you could ever need. We might want to think about using multi tapped coils to limit current production.
I am starting to see things differently now with my newest rumblings. I'm getting good ideas to start testing. Got my iPad for testing my devices. It has a built in emf meter and tons of gadgets to film my experiments. It has aluminum case which should shield it some from any electric fields.
I started testing the room I will be working in with the emf meter. I have found out that this thing is very sensitive and I have found out that my led monitor shields a portion of the emf from the AC power lines near one of my exterior walls. The emf could be thought of as an invisible light broadcasting from the power lines. If properly shielded it blocks some of that light, like light does at night and throws a shadow in a smokey room. There are also light like beams that radiate from all energized sources. Since we are hurdling through this Universe there is a great many flows we are not apparently aware of. This is due to it's resolution. Infinity is both directions both Inwards and outwards.
Through intensity and direction we can create a harness able flow. This flow is current. This field is all around us. It's density determines intensity and visa versa. The flow between two densities is the mechanism all natural processes use. Rarefaction of the density is what we are after then design a way to channel that in a one way style as it recoils back to the main density. This snap back is entirely free and with the overshoot upon intensifying the field and the recoil we net more out then in. Well that's the simple math portion. I'm not going too far into the math. It is the method that is most important here.
I'll show a video of a very important find about seeing this electric field and how it condenses around a center electrode like the ground wire TK'S used.
