0 Members and 75 Guests are viewing this topic.
hartiberlin
Quote from: hartiberlin on July 03, 2009, 08:15:41 PM
What will you see on your scope ?
Big 50 or 60 Hz sine waves from the ground "failure currents" going back to
the power station !
This is what you can tap if you have the right circuit and this is
what Kapanadze is doing !
You need to do this via a displacement current resonance method,
then you only need 1 wire as Kapanadze is doing it.
He pulls the current back and forth in resonance with the earth currents through his
transformer via his big black wire coming from the water pipe.
This way he transform the resonating displacement current AC via his
big transformer coils to the bulb loads and thus have a matching
impedance.
jeanna
QuoteContužinous work of installation is not very long, possibly, the inverter works under maximum or overloaded mode.
I am sorry to see this. I noticed it and wondered.
It seems to only run the lights without the battery as long as it ran with it.
something is missing in this.
I was sure the black box was an ignition coil, because that would do it.
That is what this device needs to fire up from a low voltage source.
It needs to use the earth battery as a low voltage generating device.
Then, this would be a device that will not ever turn off.
Hmm.
My computer is getting too hot. I can't keep typing... sorry. I will check back later...
Thank you justas. Your contribution is sooo valuable.
jeanna
hartiberlin
Quote from: jeanna on July 03, 2009, 08:22:03 PM
jeanna
No Jeanna,
the black box is a power supply with 220 Volts AC in and
12 Volts DC out.
This way he uses some of the output power to generate
enough 12 Volt power to supply the blue 12 Volts to 220 Volts inverter,
so he can disconnect the 12 Volts battery !
All very easy if you watch the video carefully.
In the newer video with the acrylic case he
has it very much enhanced all, so he can just start the circuit
with just ONE 9 Volt battery and then run it in selfrun mode.
hartiberlin
hartiberlin
