0 Members and 290 Guests are viewing this topic.
baroutologos
i found some time and played with Dole's transformer setup.
Its a weird looking thing, but after some hours of experimentation i can say that is more or less a standard Tesla conversion apparatus.
Experimental steps:
First i took my usual 40mm OD ferrite core (10x grey ferrites) and wound a 50turns 190uH coil. (red wire) By pulsing this coil by 2.2 nf 10Kv high quality RF caps in series, and by inserting a copper tube inside the ferrite cavity, nothing is happening.
Then i added a 12 turns, parallel to ferrite core winding (black cable) that gives a very large inductunce of 12mH (some 100 times more for lesser cable length) and connect the windings together (checked both ways of connection btw).
Then the lamp is lit by appling it to copper tube endings! Have not seen anything like that before. By the way, i spent few hours with it and i concluded that the tube acts as one turn to the parallel winding.
I connected a bunch of wires together and passed through the core, but no added effect. Regarding measurements, my PWM , FET, ingition coi and spark-gap configuration is a quite non-linear system. In best tunning some 50-60% efficiency was attained. (by applying a large current bulb 45w 12v, whereas smaller lamps gave diminishing performance.)
Ground usage in my setup made system a bit more stable.
I changed the little caps with 25nf 10kv x 2 in series. Same effect and some increased efficiency observed, and greater stability of the system.
Those findings so far from me,
amigo
Quote from: xenomorphlabs on May 02, 2010, 07:51:27 PM
@amigo: So the point of your post is?
Let people speculate as long as they want. It´s their freedom of speech and their decision what they do with their time.
Your words reflect a lot of "Everybody should act as I want them to"-attitude. Please contemplate about yourself a little.
The point of my post is to start a conversation about honesty, truth and facts. Also, to begin realizing when we are being duped, too.
But looking at your reply, you seem to prefer to believe in fairy tales...
eugin_b
Quote from: baroutologos on May 03, 2010, 07:10:17 PM
Nice job! Can you post schematic for your experiment? Have you oscilloscope?
dole
grizli
Quote from: dole on May 02, 2010, 06:30:31 PM
Hallo again,
Here is fast end dirty drawn circuit, simply we charge condensers in series and discharge them in parallel through the small spark gap, rather say arc, resulting in current rush in very high vibration. It is look like only magnetic. I cannot measure anything before I transform it again through capacitive coupling or like in this last video inductive coupling. I will post some pictures of components. (2 x 202K 40kV in parallel on each side, ignition transformer 10kV, 220V inverter)
Yes I have very much to tell, but its feels sometime that it can hurt someone including me so I usually don’t.
This conversion is totally could, lamp will barely become warm in full brightens and it is totally harmless, no burns, I tested discharge of several cm between hands without any injury, but it is very sensitive to get it proper. I believe that with proper adjustment we can achieve any effect we could imagine, tuning to resonance.
I’m sorry for short disturbance, there is so much we do not know and see.
d.
Light bulb is connected directly via SINGLE wire that goes through coil ?
