0 Members and 49 Guests are viewing this topic.
jbignes5
 So no one is gonna build the special transformer then? You can simulate all you want with off the shelf parts but the secret is in the can/box/covered bases. That secret is that transformer that excites the heavy copper coil and creates a flow to the central ground which generates real current in the load coil between the two parts. What creates the 50 hertz is the spark gap. That 50 hertz is actually very complicated impulses with duty cycle breaks( sparks gap ).
like I said I will be making the transformer so all can see this in operation. Try looking up the slayer exciter and the effects it has on everything in the field it provides, it runs on the same premise.
Zeitmaschine
Quote from: cheappower2012 on February 17, 2013, 06:09:33 PM
Now at the end,when I remove the ac from the inverter
the light goes out very fast,notice in the TK video theres a long delay,before the lamp goes a very strange thing not consistent
with fakery.
But consistent with a solenoid switch that shuts off the resonant circuit with a delay (AC from inverter to rectifier and filter capacitor in the can).
The use of the inverter is completely illogical. Why should the generation of a lot of energy have the need for a small amount of continuous energy input? Imagine a campfire lit with a matchstick. As soon as the fire blazes the matchstick is removed. Now the fire goes out? Would be strange.
But if the inverter is just to have a reference frequency of 50Hz then it would be much simpler to use a small circuit (555 timer) instead of such a huge inverter box.
Of course if the inverter is needed to supply the fancy spark generator with energy independent of the energy generated by the resonant circuit then it would make slightly sense indeed.
So keep on looking for a resonator which can be started by a single input pulse (from a battery).
core
Quote from: Zeitmaschine on February 17, 2013, 10:00:00 PM
...The use of the inverter is completely illogical. Why should the generation of a lot of energy have the need for a small amount of continuous energy input? Imagine a campfire lit with a matchstick. As soon as the fire blazes the matchstick is removed. Now the fire goes out? Would be strange.
With all due respect that's just a silly analogy that speaks nothing of how the device may operate. However dwell on this analogy.
Imagine a pilot actuated pneumatic device that has a 0 – 20 psi main signal and a 0 – 1 psi pilot signal. So when pilot signal is 1 psi it allows 20 psi to enter the pneumatic bladder and do work. You see when the pilot signal is removed there is a time delay before the 20 psi deflates the bladder. This is a little more realistic.
BTW - For those who know something about refrigeration. Do not we see the same thing when we shut a compressor off? The refrigeration effect is maintained until the system equalizes. Our time delay.
Step 1 should be to define all the states of matter and there 'state'  changes.
Your beloved
-Core
core
Quote from: jbignes5 on February 17, 2013, 09:39:46 PM
.......That secret is that transformer that excites the heavy copper coil and creates a flow to the central ground which generates real current in the load coil between the two parts.
Bizarre is the only word that comes to mind when I read this. Not trying to insult you but you would be better served saying that there is a hamster in a squirrel cage in the green box.
The first and only question to ask is: Where do we tap the extra energy from? If it comes from the air then the air must be 'pre-conditioned' first as it is in a neutral state. No other questions should be asked until this one is satisfactorily answered.
Your Beloved
-Core
verpies
Quote from: core on February 18, 2013, 12:49:35 AM
Most of his posts are incoherent .  Try to see what happens when you attempt to have a rigorous and logical discussion with him.
I gave up a long time ago and started filtering out his posts with a browser plugin... but maybe you'll be more perseverant and successful than I.
