0 Members and 514 Guests are viewing this topic.
core
Quote from: jbignes5 on February 18, 2013, 09:51:16 AM
........... What is really bizarre is Verpies pretending to be another user.
Huh?........I understand that this thread spans over 1,000 pages and its impossible to read it all. However a little research and you would of seen that I have been on this thread well before Verpies and WELL before you registered for this site.
Your Beloved
-Core
BTW - @All At one time there was a member that went by the name LtBolo. He had some good ideas and no longer posts on this thread. However at one time he spoke of 'electron' acceleration via a Tesla coil. Its worth your time researching what he was saying, add to that the effects of a magnetic field on ions (positive and negative).
Here is a very helpful picture. Step 1 understanding the states of matter.
Question: What is the difference between 212 Deg.F water and 212 Deg.F steam?
Question: Can a meter measure Latent heat? or can we only measure Sensible heat.
Dwell on it.
d3x0r
Quote from: Grumage on February 18, 2013, 03:42:55 PM
It's the primary winding that has got me foxed, Quoting "The primary P P is wound in two parts, and oppositely, upon a wooden spool W," Is this calling for a bifilar style? Quoting "Each half of the primary has four layers, 24 turns in each, this giving a total of 96 turns." What size wire? Wound in two parts and oppositely??? Opposite to what? Secondary? Give me some clues and I will endeavour to build this.
It's a caduceus coil, not so stange.
verpies
Quote from: core on February 18, 2013, 08:23:50 PM
I miss LtBolo's input here.
If the electrons get accelerated to energies above 14eV in air then they will cause secondary electron emissions upon collisions.
Magnetic field will confine electrons and ions to opposite spiral/circular orbits, delaying or preventing their recombination
Their energy density will differ.
Zeitmaschine
No unusual behavior of my Joule Thief circuits so far to report, except there was no smoke cloud yet while experimenting (that's indeed very unusual). :(
But found something interesting about electric parametric resonance in German: Physik des Schaukelns und parametrische Verstärkung
Essentially it says the capacitance should be lowered (go to higher frequency) when the voltage reaches its peak, not raised (to lower frequency). I always thought it is the other way round. Very odd. ???
And something even more interesting about capacitors, hence a short lesson in physics:
A capacitor consists of a set of two parallel plates of area A separated by a distance d. This capacitor is connected to a battery and charged until its plates carry charges +Q and -Q. The battery is then disconnected. If the separation between the plates is doubled,
(a) the energy stored in the capacitor is halved.
(b) the energy stored in the capacitor is quadrupled.
(c) the energy stored in the capacitor is reduced by a factor of 4.
(d) the energy stored in the capacitor is kept constant.
(e) the energy stored in the capacitor is doubled.
The correct answer is (e). Look it up.
Now the one million dollar question: What would happen if there were a way to double the separation between the plates of a charged capacitor without the need of any energy input?
Ideas are welcome ... :)
jbignes5
Quote from: Zeitmaschine on February 18, 2013, 09:40:09 PM
I do believe that's voltage increase or potential of the two plates and not energy. Like in transformers the charge changes into voltage potential like in a step up transformer when the distance increases between the plates. What's this got to do with TK's device?
