0 Members and 436 Guests are viewing this topic.
forest
Investigating not published circuit is a nightmare. Better try to find the way it works.I think it is based on creating magnetic bias with low voltage but larger amperage and then using HV pulses as a switch to switch Bloch wall position in space. In effect magnetic field looks like moving around or pulsing with any required frequency.Now, you know that having weak magnetic field pulsing fast is the same as having large field pulsing slow , the difference is only required stage of frequency correction.
baroutologos
Today i reconstruct my setup so as to be fed by mains.
An 220/12 transformer with FWBR, smoothing cap and ammeter to the system was added. My 555 timer circuit does not work as intended 50Hz, and many fellow experimenters may confuse 555 malfunction by RF for a ganuine effect.
So i applied a small 220/9 volt transformer for pulsing the inverter transistor pair. several coils were tested. Inverter works nice and if a coil of 5mH + is applied a nice and strong pulsating field is produced.
A plier held on coil's core strikes the core like a small bell. I decided to remove ferrite core and audio wire coils and replace it by a long audio coil, that has laminated core.
This coil is intented for use till a couple of Khz, with few losses. Laminated are extra thin, 0.3mm and i can add or remove them so as to control core saturation level.
Two windings were wound on core. One 1mm enameled wire, 150 turns 0.25mH without any core, 2-2.5mh just with the addition of a couple thin laminates. (max laminates are 30) One receiving winding wound on top of it 160-170 turns, biffilar (for having the option of doubling it)
Inverter while running draws some 2 amps at 14volts. A lamp applied to the receiving winding barely lights. This inverter is quite lossy (pulsing a coil without any inverter setup is far more efficient)
For applying the rf signal, a 3 turns copper tubing was applied to enclose the coil. I refrained from wounding a large impedance coil for applying the RF sincce the large inductunce chokes all high frequencies.
I spent some time experimenting at adjusting ignition coil pulser, spark-gap distance (carbon electrodes) and the use of a ground so as to have max Rf noise. Rf noise was detected by a electrical tester screw driver with a neon bulb. Max brightness equals mas Rf noise.
I found out the application of ground at the correct side of spark-gap greatly enhances RF noise. This RF is diffused to the whole circuit, transistors, transformers etc.
I add-remove coils core laminates and played with spark-gap. No bulb's increase in brightness observed in any case so far.
fullbit
News from Rusia
It sparks with/without source/ferrite.
http://next-energy.2x2forum.ru/forum-f1/tema-t10.htm#3778
http://www.001-lab.com/001lab/index.php?topic=455.300
Re: Tariel Kapanadze and his "miracle generator"
by SOS-SOS Yesterday at 9:34 pm
All once again with the day
the radio. And the upcoming Victory Day, the day of the Great feat of our forefathers, and to whom, and
fathers. YAHOO! Comrades, for they are worthy of respect, they were able to understand about themselves
in difficult times. The times that we never dreamed of, when a person goes to the man with a weapon and
kills him staring at each other's eyes. And all because of what that sheep with sick
minds and a desire for omnipotent power. So let this lesson, for which our forefathers
sacrificed their lives will not be lost. In order to remember every person he knew
who he is and do not bend do not under any machinations evil.
I wish you all do not
be like such people, myself, in principle, too, the same. For it is the same
person as all of us and each of the at. Fed compounds the simplest
of atoms. Hydrogen and oxygen atoms forming water. And for constant
consumption mix a little more complicated. Our air ... As well as food ... The three
components ... simple, more complex and more difficult, and only in combination and in
dosed quantities with them we can live!
and energy,
it can be, but we must create the conditions, the conditions for its inception her life.
And I will say so,
people who understood how to achieve it - really brilliant. And if they
are any on this planet it is not just. You are given the chance, you
have the key to changing the history, the key to the new trend of development of our planet. And silly
having such capabilities and knowledge not to try to turn history. You are
thus the momentum with which runs your machine and then goes on
thumb while working on itself.
But to blame
mortal body, our organic spacesuit spiritual identity, which dictates the rules, the rules of the
territory, where we are. The territory of
planet Earth. That's just who these rules has created, and why we are afraid that their
break.
Let's look
at the sun. There are also the simplest atoms, but there is other processes. Hydrogen at a certain process is transformed into
helium. Thus gives us light and energy. And why, yes because there is no
man! "
So you and our
case there is no limit a source of energy, but the question is that he is in the hands of
man. And what gets people, it
automatically becomes a paid and elected, as follows our human
nature.
The only thing that
annoys is injustice. There are people (a personal friend) that your entire
life flashed this problem. The best of the worthiest. From
pre-school age began his path in this direction. Written not
a single scientific work still at school age. Have realized grandiose projects
at a paltry pittance in order to understand the issues and as luck would have it only flag in hand,
can still reel in the neck ... And these people are among us, in fact on the data
forums. And confusing. The point is that no work bearing fruit, but a banal case
of luck. And having that key people become conceited and starts dreskodit. Dreskodit And only in words, not really,
instead of what would give an impetus, the momentum is.
So ask as
a question, but rather feel like this wind, the wind of change and not brake
the movement.
all again with
the Great Victory Day and the Day of Radio, I hope that in the near future and
Day FREE energo, I hope that we will live to see this.
Macmep_L
Thank You for shared very important news from our forum, I just want to add some nice pic from dynatron, he is a guy who make self running device!
Source: http://www.001-lab.com/
baroutologos
Hello guys, i have seen the excitement and diagrams but cannot understand what they are saying. Google translator sucks a bit.
Can anyone summurize what's the claimed progress is all about?
Thanks
