0 Members and 119 Guests are viewing this topic.
forest
Khwartz
Quote from: Grumage on February 23, 2013, 01:05:40 PM
Hi Zcsaba77. The link you posted were circuits for generating HV from a motor car HT coil. However I found a circuit that is quite simple and could be used at any frequency you desire by working with both L and C. The Diode symbols represent Varactors (Varicap Diodes) but apparently you can use LED's!! But in looking at the circuit may be 2 fixed caps could be used for the sake of test. But maybe one of our more erudite clansmen will disagree....We shall see?
Hi Grumage. Is the out-put the coil?
Khwartz
Quote from: zcsaba77 on February 23, 2013, 04:36:58 PM
From french site that games was interesting, on second link what you posted electro pulsing game, I reach amplifying pulse :D
Yes, but you would have to put the resistor value at zero; means no loss. All the problem is that damn loss, in the real devices... Cheer.
NickZ
  a.king21:
  I've build and work with a similar LaserSaber cross-over circuit, pictured below.
  Some of the effects that are shown are caused by the capacitive link coming from the house wiring, which is found throughout the house floor, tables, and anything close to electrical ac wiring. If the house breakers are turned off this effect goes away. But, this stray ac capacitance is one of the reasons that the small led bulbs light. Especially if the circuit is also connected to an earth ground. May not be the only reason, but the ac link needs to be isolated, or it will affect the results.
It is an interesting and highly sensitive circuit. And may have some similarities to Dr. Stifflers SEC or PSEC devices.
I did find that it would drain the battery quickly, but also recharge it to back to the  starting voltage, again, then drain to 1/10 of the starting voltage, then recharge itself again. I used 1.5v, as an input source, as well as 7v, (white AA battery bank).
I still don't know what to make of it.
