0 Members and 103 Guests are viewing this topic.
jbignes5
Quote from: a.king21 on February 24, 2013, 02:05:16 PM
Yes, I agree. However if the parallel load is too great then you also kill the loop. With the spark gap method you get to tune it. So my opninion is that a spark gap in parallel to start with, and afterwards experiment with a quiet method.
Anyway, good luck and please post your circuits when you have  time.
Yeah the spark gap method is very very good for doing the job and having the ability of being adjustable. likewise you can add the magnetic quench and get true one way impulses. The magnetic flow biased across the gap polarizes the gap. If this is chosen then you must adjust the circuit to handle only one way impulses. Although the tank circuit that is oscillating would not be doing so with the polarization channel. Using bifilar coils is another way to change an oscillating circuit into a polarized impulse effect.
Like I said earlier we need to contain the field inside of the unit by statically shielding the core unit then everything coming out of that unit. We only want the energizing energy to interact with materials in certain exposed areas. This allows the system to pressurize and flow with more intense fields. Adding texture to the fields like diagonal angles to the exposed material will allow for better current flow. In this example copper exposed to the fields emitted from the heavy coil will sweep through the copper and excite the metal with a heavy current flow as the sweep continues along the exposed copper material.
Grumage
Quote from: NickZ on February 24, 2013, 12:02:27 AM
  a.king21:
  I've build and work with a similar LaserSaber cross-over circuit, pictured below.
  Some of the effects that are shown are caused by the capacitive link coming from the house wiring, which is found throughout the house floor, tables, and anything close to electrical ac wiring. If the house breakers are turned off this effect goes away. But, this stray ac capacitance is one of the reasons that the small led bulbs light. Especially if the circuit is also connected to an earth ground. May not be the only reason, but the ac link needs to be isolated, or it will affect the results.
It is an interesting and highly sensitive circuit. And may have some similarities to Dr. Stifflers SEC or PSEC devices.
I did find that it would drain the battery quickly, but also recharge it to back to the  starting voltage, again, then drain to 1/10 of the starting voltage, then recharge itself again. I used 1.5v, as an input source, as well as 7v, (white AA battery bank).
I still don't know what to make of it.
Hi Nick Z,
Would you be willing to share your version of the circuit with us?
Having noted your post's today and having all the components to hand I quickly built a "mock up" using a 24/240 V Iron cored transformer (10:1 ratio). I was able to easily light a 240V 11watt CFL using my body between circuit and ground but only at 12V supplied and an operating current of 600mA. Way above 11watts!! No OU at this stage :)
Cheers, Grumage.
NickZ
   Grumage:
   The circuit that I was testing was the LaserSaber cross-over circuit. But, I've had the best result from his Joule Ringer 3.0 circuit. Here is the diagram of the cross-over circuit.
But, the 3.0 version is an easy build only needing one component (2n3055 transistor).
To this I've made several versions, using various transformer cores, and different coil configurations. I try different things to see what works the best. Whatever doesn't burn up and makes the bulbs light brighter is what I keep, while working towards even more light output.
Farmhand
jbignes5
 I had a chance to go over the new theory of everything, you know the magnetic one. It definitely looks good from the magnetic point of view but my one question is where does the magnetic fields come from? How do we synthesize the magnetic field currently? You got it provide a voltage and the current will flow and the magnetic fields form. He tells us by admitting that he needed to use 70k volts in the vacuum chamber. Also how come he has to have two bowls made of matter to get the fields to form?
Anyways if this universe was all magnetic how could the fields separate. Wouldn't they all just stick together? And if this is the way it is then how come the universe is speeding up wouldn't it be slowing down or become static? The universe is so vast that only potential can breech the gaps of light years in between galaxies. It is indeed an electric universe and not a magnetic one. The magnetic is only a byproduct of the electric field. Yes it can convert back and forth but the potential is the real key.
Not once in his video did he show anything about the electric fields and how they relate to his bowls. If he did look into this he would find the true structure of the natural medium and not the byproduct.
