0 Members and 145 Guests are viewing this topic.
NickZ
  Thanks to all for your comments concerning the Dally type of circuits.
  But, to think that all TK devices as well as Dally types or similar devices are all fakes, without being able to show or prove HOW, is not going to help us much.
Even if only one of those circuits is really working as shown, that by itself is enough to continue to research the cause of this anomaly. Once someone replicates any of those devices, we'll have something more to go on.
  I agree that the Lasersaber circuits are not self runners, as they are simple inverters, only, even in his newest Cross-Over circuit. The house wiring ac. capacitive link may be what is responsible for the led bulb lighting. Once the power supply is removed and the house breakers are turned off, the circuit dies out.
The newest Exciter circuit shown by Slayer has been able to drop the input source draw substantially, to very efficient levels, of about 1/3 the previous draw, simply with the use of a second 2n2222 transistor.
At least both are headed in the right direction, even if they do require an input source, to obtain useable light.
  There is another Dally circuit that is started with a hand crank generator to charge a capacitor bank. Have you all seen that one. I know that this may be nothing new, but it is still very interesting, if nothing else.
  Why are NONE of these guys lighting their house with these circuit???
That,  is my question...  As I certainly would be doing it.
Hoppy
Quote from: NickZ on February 26, 2013, 12:11:12 PM
If TK is using an external power supply and transforming this to HV to run his lamps, then he may have found a very efficient way of doing this and could even have achieved OU. I do not rule this out completely, but IMO its a lot more likely that he has not achieved an OU running system. In order to make progress to discover HOW he does it, all possibilities need to be explored and this includes the use of an external power supply. Ruling this out just because the assumption is that he must extract energy directly from the ground or aether to achieve OU is just limiting viable options.
I've seen the 'hand crank' video and there is just not enough detail about the setup to make an informed opinion.
As for why you say that none of the demonstrators are lighting their houses with their setups assumes that you have it on good authority that they are not. A non-OU but very efficient setup is still very useable and in the case of lasersaber, I understand that he uses a JT system in his workshop. I have also heard that Bedini has LED lighting in his home and runs this from one of his devices.
NickZ
  Lasersaber is lighting his workshop using a solar system as the input source to charge batteries, which are then powering his circuits.
Nor have I seen a single video of someone actually lighting their house, including TK, John Bedini, or anyone else,  from a free energy system.
As these circuits can be used for this purpose, I'm surprised that not one person is doing it, at least that can be shown, as some kind of proof. Not just hearing that JB is doing it.
I'm not knocking it, just would like to see if anyone is doing it.
  I agree that an efficient led lighting system can be incorporated to substitute or compliment the house grid's input. But, not one video is showing this, especially from a truly free energy system, using no external man made input source.
If I am wrong about this, please let me know.
  I am open to the possibility of ANY Source being used for this purpose, at least to kick start the operation of a circuit.
pepsimaxzu
I have a question. if is input in kapagen cca 150w and output is for eaxample 1500w. u can join output on input, cant u? it will be selfruning kapagen with 1500-150=1350w output or not?
Hoppy
Quote from: NickZ on February 26, 2013, 01:12:56 PM
The problem is that a video in itself is not be able to prove that any domestic system is working 'free energy' in the OU sense. It may be the case that none of the circuits so far presented are capable of running OU!
