0 Members and 177 Guests are viewing this topic.
a.king21
One of lasersaber's circuits is a self runner and Hoppy is terified that we latch on to it and work on it.
dllabarre
Quote from: a.king21 on February 26, 2013, 03:05:13 PM
Which circuit is the self-runner?  Please post schematic and name of circuit.
I thought I saw (built many) of all of Lasersabers circuits.
Thank you,
Don
Grumage
Eureka or flash in the pan?
Hi All,
Posted below are two pictures, first is of Sinus input from Signal Generator @ 1v P/P (for some reason I can't put a scope on the O/P of the Audio Amp as it shorts) Second trace over 120 V P/P.
Voltage peaks at 28 Khz. Output is off 30 SWG at 250 turns under the black tape. This coil was the start of an aborted project but it took so long to wind I kept it! The O/P voltage is not capable of  load but with thicker wire who know's?
Second picture is of the Ferrite core, the sort of horizontal winding is the last layer from the secondary of an old microwave oven transformer. I estimate the gague also in the 30 swg bracket.
Input current appears to be 200mA. But what I found encouraging  was the massive voltage gain.
Comments Welcome.
magpwr
Hi,
If anyone plans to work in lasersaber joule ringer crossover circuit.I have pasted the link to Laser's forum on joule ringers crossover circuit .I was active in that forum and worked on replication.
http://laserhacker.com/forum/index.php?topic=70.0
Yes the device work in home trickle charging battery or caps but none near his work related to lighting a bulb.
NickZ
 @ delabare:
   There is also a later update to the cross-over circuit, showing that the bounce back effect of the transistor is what can cause the capacitor to self recharge. But, the led bulb's light output is very low and not really useable for lighting purposes. If more draw is being drawn taken from the circuit (brighter led light), the battery or capacitor will discharge, but will recharge back to starting voltage once the additional load is removed.  This only proofs that the capacitor has a slight recharging effect. But, that is not anything like TK's strong current output devices.
