0 Members and 495 Guests are viewing this topic.
Grumage
Quote from: zcsaba77 on February 28, 2013, 02:33:41 PM
Hi Grumage
On your device is amplifying pulse or keep same voltage peak?
Hi zcsaba77,
I am sorry I don't quite understand your question, do you mean in Phase? Just to clarify, although I could not measure the input voltage P/P value, it can't be more than 8 V P/P  because the amplifier is only fed by a 16 V input. I spent a fruitless yesterday trying to improve the current output only to find I had destroyed the amp module.
On a different note has anyone looked into the loading of the Strange Russian transformer. I watched a Youtube vid where a guy kept on hanging Led's but there was no mention of how that reflected on the input side. The whole lot was being powered by a single AA battery.I ask because I am Ampless at the moment :)
Could we be so lucky that it did not reflect back? Probably not!
Hoppy
Quote from: a.king21 on February 28, 2013, 03:37:02 PM
A good introduction to radiant energy is here:-
http://www.4shared.com/video/PvmfKu0T/Energy_From_The_Vacuum_Part_06.html
He also explains the gating of the Bloch wall as a generator of vacuum energy.
My understanding of Bedini's theory is that the Bloch wall is in effect a portal / gate for the entry of aetheric energy, not the generation of that energy. The Bloch wall acts as a an aetheric pump through  expansions and contractions caused by a pulsating electromagnetic field.
a.king21
Quote from: Hoppy on February 28, 2013, 04:32:07 PM
Yes, my wording was clumsy.
truesearch
@Hoppy:
That reminds me again of the "Richard Clark" writings and diagrams referencing "Bloch wall" manipulation. See following picture.
truesearch
zcsaba77
Quote from: Grumage on February 28, 2013, 04:20:52 PM
Hi zcsaba77,
Hi Grumage
I try put question else:
Your output signal is amplifying (ex: start from 8Vp/p and finish on 32Vp/p and send by spark gap over to load or next device) or sinusoid signal is keeping level(not raise, not fall), I see on your scope sinusoid signal this is input or output?
Because I playing with this:
http://www.sciences.univ-nantes.fr/sites/genevieve_tulloue/Elec/Transitoire/Condensateur1_flash.htm#
....and I saw if I switch in good time signal raise, but little bit later I can not raise signal more, keeping voltage peak to peak, my opinion (maybe is wrong theory) if I can not raise more, need send away power/voltage, and raise again from beginning.
