0 Members and 361 Guests are viewing this topic.
phoneboy
Quote from: Zeitmaschine on March 04, 2013, 09:25:24 AM
Apropos »shielding«:
Kapanadze has clearly visible soldered a sheet of copper onto his tin can. In my humble opinion there can be only two possible reasons for doing this. The first reason would be to hide the wires. But this could be more easily accomplished by wrapping the wires with adhesive tape. The second reason I could think of would be that inside the tin can there is something that has to be shielded very thoroughly.
So what could this be?
Is there a second capacitor or coil in the tin can (in addition to the visible ones) that needs shielding? But shielding from what? From the earth electric field perhaps because copper is not suitable to shield the magnetic field (even less the gravitational field)? And could it be that this shielding is the one component Kapanadze is referring to when saying that he has to make one component himself?
Maybe it's time to search for a proper tin can to do some experiments with it ... 8)
Bingo!
It should be: Is there a second capacitor/coil in the tin can
leo48
The shield is connect to ground and the strip connect one wire?
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
jbignes5
Quote from: phoneboy on March 04, 2013, 11:25:49 AM
Bingo!
I have already shown the special transformer tesla used and is most likely the same in the copper can. The copper is for shielding as Tesla recommended for proper use of the coil oscillator. It's most likely oil filled as well upto the wires hole. I am assuming that the oscillator is so sensitive that it would have negative feedback and needs to be shielded to provide a clean oscillation source. The can itself does not need to be connected to anything since it is a static shield.
Zeitmaschine
Bingo!
Why should it not be: Is there a second capacitor and a second coil in the tin can? ;D
The tin can is connected to earth (via the white wire going through the big coil) so there is no electric field in the tin can, it is a Faraday cage. So what happens if we put one half of a resonant circuit (maybe parametric) in a Faraday cage but the second half stays exposed to the earth's electric field? Then there should occur a difference between the two parts of that circuit as stated in the TK patent, shouldn't it?
And one more idea: Could it be that the whole purpose of grounding is nothing more than to have the maximum shielding effect of the Faraday cage?
Image below: All the aluminum boxes are grounded very thoroughly with brass strips. But I don't think this was done just because to minimize the risk of electrocution. Hence could it be that TK's »secret« hidden in plain sight is named »shielding«? :)
Zeitmaschine
OK, while people here are busy with shielding all sorts of things ...
... I have to ask one question: Is this demonstration actually the demonstration of anti gravity or have I misunderstood something?
Professor Eric Laithwaite gives a demonstration of a large gyro wheel
So the professor holds a weight of 40 pounds (18kg) with one hand and swings it over his head, right? ::)
What would Schwarzenegger say to this? :)
