0 Members and 611 Guests are viewing this topic.
forest
Nowhere  ;D isn't that AC current  ::) they are pulled and when AC crossing zero they return back, at least I imagine that so. In fact they are almost not moving , just energy is flowing.
Btw,In TPU current is a problem due to rectification into DC and missing ground connection.IMHO TPU require a load always connected
the_big_m_in_ok
@znel,
With respect to Reply #1620:
A couple of theoretical questions?
Will an ordinary MOT work in place of a NST?  Will the efficiency improve or deteriorate?
Doesn't the neon get blown out by 10 kv pulses?  Even if they're short in duration?
Something to think about.
--Lee
znel
Quote from: the_big_m_in_ok on May 10, 2010, 12:16:35 PM
@znel,
--Lee
I haven't tried a MOT with that experiment but I would imagine as long as you can create a resevour of HV DC in the cap it would react the same way.  How you get it isn't as imortant.    My original one was done with a 2500v Ventex where I noticed it originally.   Higher voltages produce better results.  Keep in mind 16 joule and above HV DC storage is lethal, 5 joule at 6500 volts hurts considerably, make sure your caps are no larger than .25 uf for experimenting as the chances of making a mistake is high.
The output through the neon has to be controlled, as does any output path.  A direct connection will obvioulsly discharge the cap ( and most likely blow the neon ).  I used a light bulb with tin foil over the top portion as a capacitor or corona discharge of sorts to only allow a small portion of the energy in the main cap to be released.
Dynatron is using 2 spark gaps in his design to control the discharge.
the_big_m_in_ok
Quote from: znel on May 10, 2010, 02:09:09 PM
Right.  Since I have no old TV(s) to salvage, other kinds of transformers may be needed.  Even hand winding a transformer would allow one to design exactly what's needed.
Exactly, yes.  In a rainstorm, the fatal current level falls considerably.  3,000 volts from a static charge on a doorknob can be a sharp sting to some, along with a 'snap' arc.
Very interesting.  An inexpensive, self-constructed HV capacitor.  Is coronal discharge between the aluminum and the base a problem?
It can be a backup safety feature for excessive voltages in some designs.
--Lee
znel
Quote from: the_big_m_in_ok on May 10, 2010, 02:28:07 PM
  An inexpensive, self-constructed HV A.  Is coronal discharge between the aluminum and the base a problem?
--Lee
I put tin foil on the very top portion of the bulb so there was a 1.5 to 2 inch distance between the base and foil.   The actual discharge is inside the bulb similar to a plasma globe.
