0 Members and 110 Guests are viewing this topic.
jbignes5
Quote from: Grumage on March 09, 2013, 02:19:09 PM
Sergey Zatsarinin transformer.
For the record.
Hello all, I have been continuing with experiments on the above as I feel it is part of the heart of the beast.
I have some bizzare results to share and for you to disect or digest as you see fit.
I am running a modified Royer oscillator (see below)  into a split 22mm Copper tube with 8 Ferrite torroids Permeability 7000.
Open circuit condition:-                 Vdc 12, I 1.04, F 65.3 Khz.
Shorted with single wire:-             Vdc 12.2, I 1.0, F 575.9 Khz.
Load 20W 12Vdc halogen bulb:-   Vdc 5.8, I 5.41, F 37.8 Khz. Low volts due to power supply being unable to provide.
The oscillator is a fixed frequency, but as you can see it changes frequency due to load condition. What I dont understand is why under a short circuit condition the current falls and the voltage rises.The other is why when a resistive load is applied the current goes through the roof.
Any answers?
A few questions for you.
The increase in frequency is from the primary or secondary side.
Where are you measuring the voltage or current rise? Secondary?
On the schematic you are using a core? If there is then you are limiting the frequency even more. All cores do this. This is why Tesla used no core and wound the secondary on top of the primary. Imagine the frequency you would measure if there wasn't a core.... Again Tesla used a bifilar type primary. This was to reduce the reactive portion of a standard solenoid from the spark gap impulses. And then only the natural resistance or the wire was left. This allowed for a speeding up of the impulse beyond what was normal to standard coils and hence a gain of energy could be obtained.
Tesla did a great many experiments on charged particles and even when the charge was the same if the speed increased then an increase in energy was secured when that charge hit an object. This is the whole premise behind his death ray.
Grumage
Quote from: jbignes5 on March 09, 2013, 04:13:17 PM
Hello jbignes5,
All DC measurements were carried out on the input to the oscillator, the frequency measurement was taken from the output to the single tubular primary. I suppose you could say that the transformer has a core but it wraps over the primary. The secondary (just a single wire) runs through the tubular primary. As you are probably aware Royer oscillators find, and run at,  their resonant frequency, I wonder  if what is happening is cased by the change in circuit parameters?
Any way I will keep on investigating.
jbignes5
Ok I looked up the Royer oscillator and it seems straight forward. But that is a DC to AC converter. DC in to AC out but the AC is not sinusoid. It is a square wave AC output.
This is not what I have talked about in the slightest. Yours is center tapped and the Tesla oscillator is not generally centered tapped. The Royer oscillator is also saturable core transformer which can give weird outputs as you have seen.
The transformer I suggested is a new breed of static like output because it raises the voltage beyond what other transformer can do.
leo48
Quote. The Royer oscillator is also saturable core transformer which can give weird outputs as you have seen.
The load alters the inductance of the coil and thus the frequency must be recalculated as a function of the new values​​.
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
elementSix
 Having a low voltage winding and a HV winding, using also Coax Cable..
Maybe this might point us in a better direction.---->>>
The invention relates to electrical engineering, to energopreobrazovatelnym devices and can be used in the power supply of electrical devices and systems. The technical result is to increase the flexibility and adaptability of the output parameters of the control transformer, extended output power parameters and the possibility of fine adjustment. Resonant transformer includes a primary and secondary coaxial coil. In the interior of the secondary winding of an extra coaxially inside additional winding set of ferrite core, made an open one. 2 BACKGROUND f-ly, 1 ill.
The invention relates to electrical engineering, namely energopreobrazovatelnym devices and can be used to power electrical devices and systems.
A device for the generation of electrical energy, consisting of a source of high voltage capacitor charger, discharger besserdechnikovogo transformer primary winding is connected to the discharge circuit-charging capacitor, characterized in that, in order to ensure the operation of the device as efirodinamicheskogo electricity generator, the secondary set in resonance with the discharge, and for providing a positive feedback output transformer secondary winding is connected to the battery through a rectifier capacitor / Application RU 2003113351, 2004 /.
Known device is not available from the output low voltage consumers.
A device to capture and convert physical vacuum energy into electrical energy, comprising: a modified transformer, generator of sinusoidal current, the capacitor of the primary winding of the transformer, the transformer secondary condenser, matching element, battery / Application RU 2001109811, 2003 /.
Known device structurally difficult, not technologically to use, especially when doing this, to have limited application at high energy performance, does not meet the safety requirements (high voltage), no electromagnetic compatibility with the consumer.
N.Tesla known transformer consisting of three windings - primary and two secondary, located inside the primary. A high-voltage secondary winding, and the second low-voltage winding, located similarly high / V.A.Atsyukovsky. Transformer N.Tesla: Energy from the air. Publishing house "Petit", 2004, page 8, 7 /. The disadvantage of a small area of ​​the transformer windings interact with each other.
The closest is a resonant transformer having a primary circuit is tuned to resonance at the resonant frequency of the inductance and capacitance (resonance currents or voltages), characterized in that the coil in the primary circuit has two cores, the smaller of which contains a secondary coil, which is removed useful power, and the total change in the inductance of the coil primary circuit does not exceed (even when fully loaded transformer) of several percent, which hardly affects the resonance, is removed from the secondary power exceeds the power of email. current in the primary circuit, as at resonance, the total power at the coil of the transformer primary circuit in times of Dr (Q) exceeds the total power supplied to the primary circuit, the resonance is maintained when the transformer load or change the capacitance and inductance of the resonant circuit, or a change in frequency of a let down DC / Application RU 96108039, 1998 /.
Known transformer does not have a high Q factor, structurally complex, not technologically when adjusting the output parameters. Object of the invention is to increase the flexibility and adaptability of the output parameters of the control transformer, increasing energy output parameters as well as their smooth adjustment.
The problem is solved by the fact that in a resonant transformer, which includes primary and secondary coaxial coil according to the invention in the inner cavity of the secondary winding coaxially mounted auxiliary winding, auxiliary winding is installed inside of the ferrite core, made an open one. The distinguishing features are:
- In the interior of the secondary winding of an extra coaxial (which reduces the structural complexity, enables the implementation of technological control of power settings);
- Inside the auxiliary winding set a core made of ferrite (which provides expansion output parameters - current and voltage);
- The core is made not closed (which reduces the consumption of materials and structural complexity).
Thus, the claimed solution meets the criterion of "novelty." A comparison of the proposed solutions with peers and other known solutions are not revealed to them the features distinguishing the claimed solution to the prototype, which allows to conclude that the criterion of "inventive step."
The invention is illustrated drawing, where the transformer is presented in the context of resonant transformer comprises a primary winding 1, the secondary winding 2, additional winding 3, frame 4 coil core 5.
Resonant transformer operates as follows. In the primary of one transformer with a high frequency current pulses of short rise triggered by a pulse generator (the figure is not specified). The secondary coil 2 having a greater number of turns than the primary, the phenomenon of resonance, which is initiated by a high voltage / V.A.Atsyukovsky. Modeling of structures of matter and fields on the basis of gaseous air. "Energoizdat", 1990, p.5-7 /.
The resonant oscillations due to the secondary parameters (wire diameter, number of turns, the thickness and insulation material), which in turn initiates an extra-low voltage winding 3, which has fewer turns than the secondary coil. The additional winding can be connected if needed rectifying diodes and a smoothing capacitor. In this case, the resulting DC voltage can be used either directly or through the appropriate converters, DC to change the form of the energy needed by the consumer. Resonant transformer can work without the core, but with the transformer core power figures increase by at least 10%. Not a closed core secures the proper functioning of the transformer core saturation and without concomitant distortions in converting electricity.
Control the output of the transformer is performed without modifying the transformer, and by varying only the input action of the control pulses generated by any generator.
Resonant transformer provides increased flexibility and adaptability of the output parameters of adjustment, with the expansion of output power parameters and the ability to fine adjustment of any of the pulse generator, which in turn provides a simple and easy to navigate.
http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fbd.patent.su%2F2396000-2396999%2Fpat%2Fservl%2Fservlet8e7b.html
