0 Members and 490 Guests are viewing this topic.
zcsaba77
Hi for All
Did someone test/experiments ferrofluid cored on kapa. gen. (except S. Meyer)?
jbignes5
Quote from: zcsaba77 on March 12, 2013, 06:12:34 PM
Hi for All
Actually I suggested using a ferric power or shavings in the copper tube element to separate the magnetic field from the electric field. This in my experience is a way to make the electric field stronger and attract more free charges towards the vacuum of the ground cable in the 2004-2005 videos. But it was a suggestion that I plan on doing myself but thought others might be interested in trying if they wanted.
zcsaba77
Quote from: jbignes5 on March 12, 2013, 08:39:40 PM
Hi Jbignes5
I mean is it meaning this way, experienting with ferrofluid?
sparks
    As explained to me the magnetic field is created by a flow of virtual particles that creates charge.  Move an electron change the flow of virtual particles creating the negative charge carried by the electron.  As the electron moves through an electric field it displaces charges in that field.  The flow of virtual particles that was "charging" the vacuum is altered.  We see this as a magnetic field distortion due to the charge carrier moving.  This allows for what appears as effects at afar  (e.g. change in magnetic field around a transformer secondary or the movement of a permanent magnet when we move another permanent magnet)  This is why I truly believe there are no overunity magnet motors or generators or transformer arrangements etc.  It takes energy to move charged mass. This is why I continually come back to the line of reasoning that if electrons are moving within their orbitals they represent a scource of potential energy.  The flow of virtual particles in a neutral atom or molecule is such that the electrons assemble at discrete distances and vectors relative to the neucleus.  The atom can move through an electric field with very little effect because the virtual particle flow is mostly balanced.  Take this same atom moving through an electric field less an electron.  The ion now creates a magnetic disturbance.  Take 10to the 23 or 1 mole of atoms that was moving due to some force or other and ionize them within a created electric field and you get accelerated electrons moving towards the anode  FIRST.  They are way easier to accelerate than the neucleus which is magnitudes more massive than the electrons.  This results in a large current pulse of short duration.  In order to transform this current pulse we need to smooth it somehow.  This is what Tesla knew how to do.  This is where resonance comes into play.  Imagine two points one charged positive the other negative approaching each other.  What happens?  The air is first ionized then a spark flows through the plasma and you discharge the power supply capacitor.  Now what happens if you just move the contacts closer together without a plasma bridging the gap?  Can't you capacitively couple the charge state of one contact into the secondary?  Weren't some of the first voltmeters 2 gold leafs suspended on a string inside a bottle.  Would they not move when someone "grounded" holding a glass rod moved the glass rod near the gold leaf contact?  What moved the electrometer?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
