0 Members and 489 Guests are viewing this topic.
x_name41
Quote from: leo48 on March 15, 2013, 05:46:49 PM
yes it with google translator
усилитель напряжения ун9-27      =  voltage amplifier YH9-27
понижающий трансформатор         =  step-down transformer
Автомат                          =  automatic
конденсаторы                     =  capacitors
динамо                           =  dynamo
диодный мост                     =  diode bridge
как соединено пока непонятно     = connected as yet unclear
Скорее всего так                 = Most likely it
Алюминивая фольга внутри катушки = Aluminum foil inside the coil
нагрузка                         = load
Leo48
not this scheme error! here not 50hz. modulation!, not capacitor-coil and not resonance
this is correct scheme!
forest
Well...I don't remember if I said it here or on another forum but overunity comes from reactive power, and when it's converted into real one then COP=Q factor
forest
The secret is and was always in BELLS. Remember famous Ed Leedscalnin motto:
ring twice. As I said Steven Mark knew to whom bells ring....
sparks
  Another thing that happens when an atom is ionized is that if the atom was moving randomly (e.g. colliding with other molecules) ionization now allows for this random kinetic energy to be converted into orderly kinetic energy.  An ionized atom in a magnetic field will move in a definite direction.   A neutral atom in a magnetic field continues to move randomly in collisions with other neutral atoms.  This molecular kinetic energy upon ionization of the atom is conserved.  Depending on temperature of the gas to be ionized and the efficiency of the system the conversion of the atomic thermal energy into electrical energy can be in excess of the energy needed to ionize the gas.  As the temperature of the gas drops this allows the thermodynamic laws of entrophy to pump in energy.  The molecules are accelerated randomly by normal thermal convection or conduction on the walls of the cylinder.  The gas is then ionized with a high frequency high voltage pulse.  A magnetic field (arising from an inductor which is in parallel with the capacitance created by the ionizing chamber) is present which directs the ionized neucleus in one direction and the electrons in the other.  The voltage of the capacitor created by the ionizing chamber rises above the impressed voltage as THERMAL ENERGY IS CONVERTED INTO ELECTRICAL ENERGY.  The system is allowed to relax to allow the plasma to "cool" into a gas.  The gas is accelerated by random collisions with the ionizing chamber walls (temperature rise of cool gas) and the process is repeated at a rate determined by the thermal gain of the gas inside the bottle.  It's Tesla's energy sink.  The energy goes in as heat and comes out as current.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
gyulasun
Hi Folks,
The original word usage is wrong for this component, it is not усилитель (amplifier) but  умножитель  (multiplier).  This means that component ун9-27 is a voltage multiplier, type UN9-27  and a voltage tripler and its max input maybe 9kV then its output is 27kV.   Info here http://otvet.mail.ru/question/72545041 and here  http://teslacoil.ru/detali/un-9-27/
Gyula
