0 Members and 477 Guests are viewing this topic.
gyulasun
So capacitive coil,  hmmm  how you make such?  using Aluminium foil?
In your schematic the connection of coil L4 to L1 is missing, L4 is unconnected at its bottom wire,  is that so?
x_name41
Quote from: gyulasun on March 16, 2013, 06:57:18 PM
yes, and variants in the images :)
gyulasun
Does it mean that coil L4 is a resonant Tesla coil?  Do you know its number of turns with respect to the 8 turns for L1?
EDIT  What is the text under coil symbol L4 in the schematic?  1 turn only?
x_name41
Quote from: gyulasun on March 16, 2013, 07:07:49 PM
C=4,7nF/6,3kV. - 4 pieces (high voltage ceramic disc russian capacitor)
L1=8 turns pipe for air conditioner (inductor)
L4=1 turns foil-coil (output coil)
Hoppy
The 12V battery powering the circuit schematic shown will be 'conditioned' through alternate charge and discharge pulses and will increase in capacity as a result of lowering impedance through plate de-sulfation. This effect will plateau at some point, so its important to run the device under load conditions until the internal resistance of the battery stabilises before taking measurements of input v output energy measurements. Monitoring voltage levels can be very misleading with this type of circuit, as the battery voltage may be seen to increase for some considerable time whilst under load, giving the impression of self-running. The true test is to leave the device running until the battery voltage is seen to peak and then drop before reaching any conclusion as to its performance. If the battery terminal voltage level stays constant or increases over a period well in excess of its nominal ampere-hour rating, then this may be cause for excitement.
