0 Members and 493 Guests are viewing this topic.
Hoppy
Quote from: x_name41 on March 17, 2013, 07:45:44 AM
hello, I simply changed generator with battery, but voltage power source as I said can be different :) This schematic I made ​​it up because I did logical comparisons and analysis of this video аnd I came to this conclusion. Yes can and without the resistor of 200-300kOhm :) but with this resistor reactive power increasing more slowly
OK, understood but how can you be sure that the generator can be replaced with a battery?
gyulasun
Quote from: Hoppy on March 17, 2013, 08:17:04 AM
Neither can I, so why are we being shown a circuit that includes a battery? This is clearly unhelpful unless the battery is somehow hidden in the video.
Hi Hoppy,
Well, x_name41 wrote he symbolized the hand-cranked generator with the battery...
If I consider this circuit and the video demo on it NOT a fake then it might work as follows:
The ground with the long white cable is connected VIA the lamp load to one wire end of the single turn output coil, L4, the other wire end of L4 is either connected to the common negative point of the circuit or left floating, so the bottom line is there is no deliberately closed circuit across output coil L4, the lamp load is NOT connected directly across L4.
This may mean a capacitive coupling could exist between the ground and the total circuit, similarly like in case of an Avramenko plug which seemingly a single wire power transfer.
The capacitance may be formed from the circuit board via the air towards and into the ground / soil volume, and if I accept it to be a a low value capacitor, it should have a dielectric which air + soil, so a certain part of the reactive power which is enclosed in L1C must go through this air+soil dielectic and via the load too.  How small this virtual capacitance can be? I can only guess ranging from under 10 pF up to a few times 10 pF so the working frequency should be high,  from the some hundred kHz to the some MHz range, this capacitor value surely depends also on the length of that white cable going from the load point to the ground pipe (capacitive coupling).
Does this make sense?   I simply try to understand this as if it were not a fake, also trying to understand x_name41 thoughts on this.
Gyula
captainkt
@x_name41,is there not someone on this forum out near where this demo was shown that could just buy the gen for 2/ 3000 dollars then reverse engineer to put us all out of our misery.
Keith
guruji
Quote from: captainkt on March 17, 2013, 09:03:25 AM
Keith
Continuing with captainkt or can we do the schematic of this build so that we can replicate?
Zeitmaschine
Because all this could be a deception by the energy mafia in order to distract from any clear concept that could really work?
These are the same kind of amorphous non-proven diagrams which were around here on page 5 (!!) already and so far to no avail.
So why not simply re-use one of them. :)
