0 Members and 193 Guests are viewing this topic.
x_name41
Quote from: bass on March 21, 2013, 02:57:07 AM
x_name41
You also do not have working device by your scheme!
For the options that you have schemes in another forum asked me to check, there was no positive results. Therefore, the same can be said about your opinion. You first get a COP> 1, and then talking about 50 Hz, and who is right and who is wrong. And yet all have the right to express his opinion.
because ye held very inaccurate and incorrect experiments! 1. there must be resonance but ye you were not  reached to a resonance. 2. there must be a high frequency and power in resonance circuit... and My schemes are exactly according to the Nikola Tesla! and you are stupid idiot because i did the logical and reasonable explanation there earlier which ye probably you not have read! (gyulasun confirm them)
bass
Please do your experiments and lay out the results.
Thanks in advance.
x_name41
Quote from: bass on March 21, 2013, 08:15:24 AM
Thanks in advance.
from everything that I am exhibited I think that this is not so easy!
bass
Quote from: x_name41 on March 21, 2013, 08:33:50 AM
then neither of us can not confirm the accuracy of their thoughts
gyulasun
Quote from: NickZ on March 20, 2013, 08:26:31 PM
  Here is a follow up on the same device, with more explanations from hvlabs, if you can interpret it.
http://www.youtube.com/watch?v=Pkvfo6opaiI
  He mentions Kamnahadse? Or something like that.
  It is something similar to what I'm currently working on now, which also shows the same lighting effects.  I've been able to drop the input current from 10v, 1.4 amps, to 12v 500mAs, (or less current), with the same brightness as before. Which is comparable to the brightness of a 14watt Cfl bulb running on grid power. I'm still working on this device, but will show pictures and a video when I have it running as best as I can get it.
Hi NickZ,
Thanks for the other video from youtuber hvlabs1, I have also seen it and he also seems to improve it by reducing input power draw from 9V 200mA at 7.5 kHz operational frequency to 9V 110mA at 10 kHz op frequency.  (I believe if an even higher frequency is chosen, input power may further be reduced.)  His "method" does not seem to need a ground connection.  I am unable to see the type of his digital multimeter whether it is able to measure correctly AC voltage in the 7-10kHz range? Normally an ordinary digital multimeter is correct at 50Hz AC when waveform is sinusoidal. In his second video he measures 225-226V AC voltage across the 40W bulb... and if the output AC is at 10 kHz his measurement may be doubtful or fake...
Unfortunately, the forum page he referred to in 2011 to discuss his setup is not valid any more.
Anybody who understands Russian could listen to his two videos:
http://www.youtube.com/watch?v=Pkvfo6opaiI   and http://www.youtube.com/watch?v=wAmDpqhvxZE  and tell here if he say anything useful as a hint? Like did he mention what is inside the coil assembly (under the wrap-up)? etc.
Thanks,  Gyula
