0 Members and 482 Guests are viewing this topic.
Hoppy
Good post from Hel. As he suggests, this is the wrong direction. If TK achieved self-running it was far more likely to have been with some type of transmutation of matter.
Zeitmaschine
Quote from: Hel on March 26, 2013, 10:24:05 AM
You have an electrostatic machine, or a HV power supply capable
of delivering, say, 15 Watts, no matter how high the voltage, if you connect a 15 Watt incandescent bulb to it,
no matter if rated for 12 or 220 V, it will shine to its full brightness.
Then how many watts delivers an antenna with a static voltage difference of 200V to ground? ???
And what has the surrounding air (and its conductivity) to do with the electric field of the Earth capacitor? Even if there were a vacuum between the two plates (Earth and Sun) the electric field would be still there and there should be an option to tap it. That means, this is not about collecting positively charged ions from the air but tapping the charge of the static electric field itself. Kapanadze calls this »shaking the aether«.
So I have the suspect that, if some guy actually ever accomplished to collect and use air electricity to some
useful extent, he emploied some hard to graps trick, maybe involving magnets or alternating electric fields.
The trick with the alternating electric fields is called a parametric oscillation. Therefore all the coils, capacitors and thyristor/transistors. Although, as it seems, there are several ways to achieve a parametric oscillation, maybe even without semiconductors, like the Testatika.
Quote from: Hoppy on March 26, 2013, 11:42:49 AM
I don't think a carpenter (Stepanov) connecting his disk saws stumbles over transmutation of matter by chance. And I also don't think there is transmutation of matter involved when an ordinary arc welder makes the power meter running backwards (as reported by some people).
jbignes5
you guys are missing the main point of all of this. It is the electric field and the way it is vibrated that makes air at our level conductive. Did all of you not read Tesla and his method of transferring real power without much loss at all? There is a way of reducing the anti conductivity of the air and it is only attainable via the electric field and the longitudinal method.
In the case of small devices we would need to stimulate the already established electric field of our planet. That field is longitudinally extending all the way out into space. We know this because there is a magnetic field around our planet. We know you can not have a magnetic field without the e-field as well. This field is already existing around our planet. All we need to do is intensify that field and it will make a connection to the highly charged outer surface of our atmosphere and allow us to tap those charges. This is like poking a hole in the bottom of a lake and letting the water run out of a tube and generating from that water flow. Instead of water we replace the lake with the bounty of charges around our planet. We let it flow towards the planets vacuum and intercept it and use it before it gets to the vacuum and negate it's pull on the charges. It is the ultimate hydro dam. It will flow like water.
Hoppy
Quote from: jbignes5 on March 26, 2013, 12:43:47 PM
I think you are missing the point! Are you seriously suggesting that TK transmitted power through the air, enough to light his 1kW bank of lamps?
Hoppy
Quote from: Zeitmaschine on March 26, 2013, 12:30:45 PM
......And I also don't think there is transmutation of matter involved when an ordinary arc welder makes the power meter running backwards (as reported by some people).
Agreed, more like a doctored power meter  ;D Where can these reports be found?
